Low mount AC- Who makes a custom bracket?
[QUOTE=BOXCHEV;17978877]Do the spohn mounts work with pacesetter headers?
The frame pads have to be bolted in the forward position (as seen in my third pic in post#1) With the mounts placed there there is no way the factory truck AC bracket and compressor would fit there.
I'm wondering if I could leave the driver side frame pad and mount where it is now but on the passenger side off set it so it sits back more and just create a new adapter plate to bolt the old sbc mounts too.
Likes so, move the frame pads to the yellow bolt locations, then I should have enough space to notch he frame to clear bracket and compressor.
I've got a GTO LS2 going into an E36 BMW with the stock LS2 accessory drive. The stock stuff will fit but it's tight. Would the SD7 and Holley bracket be more compact?
Also, because I'm somewhat A/C illiterate, what type/brand of compressor is the stock 98-02 F-Body compressor?
Tipsy
Tipsy
The diameter of the SD7 compressor is also considerable smaller and will allow it to fit in areas the stock compressors won't.
The stock F-body and GTO compressors were supplied by Delphi.
Would the Sanden with the Holley bracket be tighter to the block than the Delphi F-Body compressor on the stock bracket?
Lastly, is the SD7 available with rear hose connections similar to the configuration of the Delphi F-Body compressor?
Thanks for the great info!
Tipsy
Tipsy
The specific SD7 compressor that the Holley bracket is made for is the aftermarket peanut sized SD7B10; it's only available in the side-port configuration.
thanks
