L33 5.3 na performance build recipe
#61
Restricted User
I have no problem being a dick, I'm well aware of it and am perfectly OK with it - but you're the one that's also a dick yet feels the need to point my actions out without ever looking at yourself. Clearly you justify your own actions by pointing out mine. It's actually a classic case of transference - you should read this.
https://www.goodtherapy.org/blog/psy...a/transference
Tone it down.
#62
This is for 8 lug you are what’s wrong with this country right now people like you make people like me who had to do and see things that nobody can imagine but we do it so you big talking all mouth but go hide in the bushes if you had to defend for yourself in real life not on the Internet can live free.you need to wake up and be happy for having the things that you do
#64
Can we get past the grandstanding and get to the issue of "cam only, 400+rwhp, 5.3L" combinations.
I'm not being a smart ***, I sincerely want to know what I need to do in order to achieve such numbers, besides using a dyno that is located at the bottom of a mine shaft.
Andrew
P.S. I've been wrenching on cars for over 30 years and playing with LS engines since 2002.
Andrew
#67
Restricted User
Flat top 5.3, CNC ported heads (no larger than a 61.15cc truck chamber), large enough cam (23x/23x with a .600-.615 lift on no more than a 113 LSA), no less than a TBSS intake, 1 7/8" long tubes, VERY stable valvetrain, and something good to tune with.
~400whp with an M6.
People seem to neglect the fact that a flat top 5.3 with 243/799 heads isn't far off CFM capability wise as an LS1 with stock heads. A setup capable of putting a stock headed LS1 into 400whp will work similarly with a properly setup 5.3 with ~300 more RPM. The problem is, those flat top pistons are fairly critical for this goal. A low compression dished 5.3 is going to make it harder. Stock 706/862 heads are going to make it difficult. You can't
~400whp with an M6.
#69
.......I gotta 4.8 with ls3 heads and a ls7 crank with ls9 rods....I'm making 550whp in 100degree ca.weather with 5.3 flat tops. On gen 3 rods with a 58x ..tuned for e85 ..lol
#70
4.8 with LS3 heads? I doubt it. The valves would hit the cylinder walls. LS3 only works on 4" or larger bore.
#72
