Another LS swapped IS300 by dedicated-matt this time with boost and drag prep
#44
Seems I'm a bit past due for an update.
Normally for these swaps I modify a stock GM pan to clear the subframe. This is fine and all but with this being a high HP engine I'd like to keep as much oil in the sump as possible. To do so I was forced to section the front cross-member. Nothing a 4.5 inch grinder and a tig welder cant fix.
![](http://i25.photobucket.com/albums/c57/1fastsol/IMG_8522_zpsd91f3b71.jpg)
Knowing the camber/toe sweep of the IS300 was a bit on the aggressive side I decided to make my own lower control arms with the idea of minimizing the steep camber/toe curve. While I didn't take any good pictures of it; I actually performed a few tests with the car sitting on our Hunter alignment machine. With the strut removed I could raise and lower the car simulating a bump or drag launch scenario. By doing so I calculated my lower control arm length reducing my camber/toe rate. Here's the modified top hat and tubular lower control arm.
![](http://i25.photobucket.com/albums/c57/1fastsol/IMG_8515_zps42305446.jpg)
![](http://i25.photobucket.com/albums/c57/1fastsol/IMG_8516_zpsd1ecaa46.jpg)
They look cool and all but what I failed to notice is that with the strut mounting location above the center line of the the LCA upon weight transfer the strut would tend to rotate the lca. I learned something...awesome that's the idea of this project. Learning and evolving as I go
So on to the new design. Still unfinished in these pics I built some LCA's with a shock mounting point below the hub/subframe center line.
![](http://i25.photobucket.com/albums/c57/1fastsol/IMG_8528_zps50bf50fc.jpg)
![](http://i25.photobucket.com/albums/c57/1fastsol/IMG_8529_zpsf1c22f29.jpg)
Its nice to work in a shop with all the right tools and the absolute best backdrop.
![](http://i25.photobucket.com/albums/c57/1fastsol/IMG_8533_zps5996e052.jpg)
I decided to invert the double adjustable coil overs in favor of some extra sprung weight. (still with the old LCA's)
![](http://i25.photobucket.com/albums/c57/1fastsol/IMG_8534_zps9c9ca634.jpg)
The money shot (wide angle lens) Lower LCA's installed and fuctional. More updates to come soon.
![](http://i25.photobucket.com/albums/c57/1fastsol/doestires_zps1967f9ed.jpg)
#48
Looks great!
Noticed your deck surface has GM's new BS tiger stripe High/low spot surface. Do you plan to resurface the deck? I just ran across this with my little JY build as well. It seems only the newer gen4 motors have this issue. I block sanded mine so its more pronounced. Have any better shots of your deck?
![](http://i17.photobucket.com/albums/b100/Hybridgnx/79%20RX-7/enginemachinemarks_zpsa55080e3.jpg)
#51
Forcefed86 My block is at the machine shop or I would snap some more pics. The wavy deck surface is pretty typical of most GM motors I've seen. The machinist I use is ridiculously good. I consider him an artist as his work reflects a labor of love. He'll be o-ringing the deck for a nice tight seal.
Matt
Matt
#53
Awesome project! Can't wait to see more. The fender removal/tire fitting was pretty crazy, I like how it still has a stock appearance, very impressive.
I am doing a swap on a little "different" platform, it's a 2002 Subaru WRX getting an LQ4 6.0/317 heads/T56/ BW 476r billet, air to air intercooler etc on E85. Should be interesting.
#56
So I got to see this car at TX2k14 and holy crap!! Cleanest build i have seen in a long time. Car is amazing. Great engineering. Definitely one of a kind.
#57
Looks great!
