Viper T56 and 5.3
Old Dec 4, 2013 | 09:12 PM
Redlin3z's Avatar
Default Viper T56 and 5.3
What would it take to make a T56 from a dodge viper work with a L33 5.3 gm engine?
I am asking because I can get a good price on a viper transmission but is it even possible for it to work with my L33?
Thank you
Old Dec 4, 2013 | 11:43 PM
bczee's Avatar
Everything front plate forward is Incompatible as it is.
The input shaft would need to be changed or modified. Other have swapped in a GM input shaft.
The Throwout bearing would have to be change, it is of a different bolt pattern to the front plate... you can swap in a GM one or mod a GM Throwout bearing and make a spacer (.500) as the Viper one is shorter and also a larger inner dia.
Bell housing will bolt up to a Viper Plate.. But I suggest swapping it for a GM one.. that way you don't have a one off Bearing and have to mod the new one once the current one fails.
VSS sensor is a different size, pigtail and most important .. signal, which is not compatible with the GM PCM input.
BC
