Foxbody swap question
The 2.3L booster and master cylinder will work fine with V8 front brakes and I am pretty sure the rear brakes are the same.
The 2.3L chassis has the rear brake line running down the passenger side floor pan exactly where the passenger side muffler would mount, you will need to move that rear brake line. You can just swap to the v8 chassis rear brake line and it will work fine with the 8.8 axle.
You can get more information here:
http://www.maximummotorsports.com/te...8_spindle.aspx
and also I would recommend spending several hours searching through Mustang websites, these chassis and brake differences are very well known.
the rear drum brakes are all the same from 4banger to v8
