Question for those with a GTO E40 PCM Flashed to SSR/Trailblazer SS OS
I'm considering having my GTO E40 PCM flashed to a SSR/Trailblazer SS operating system (OS) because I want to be able to utilize cruise control. The GTO needs the PIM/BCM (from the donor vehicle) for cruise control while the E40 PCM's in the SSR and Trailblazer handle the cruise control functions internally.
While I'd like to have cruise control, I don't want to open a can of worms with regard to wiring. I'd like for the PCM to control the engine cooling fans and I plan to install air conditioning. I know the E40 PCM doesn't supply an AC request signal but the GTO E40 PCM can control the engine cooling fan and from what I've read, it will still switch-on the cooling fan when it detects (via a pressure switch) that the A/C compressor is functioning.
All of that said, I found this post that indicates that the SSR/Trailblazer E40 flash doesn't control the cooling fan because those vehicles have engine driven fans.
Like I said, I don't want to make a wiring nightmare where none exists, simply to have cruise control. But I would like to have cruise control if at all possible.
Any input on fan control with an E40 flashed to an SSR/Trailblazer SS OS?
Thanks.
Tipsy
Thanks.
Tipsy
My '05 Corvette ECM was flashed to an SSR by Current Performance Wiring (also did my harness). I'm using a two speed Mark VIII cooling fan. Jared has the ECM set up for both fan speeds (two different temp. setting). Harness also had an AC request (I'm using an aftermarket Sanden Compressor) that kicks on the High speed fan when the compressor is operating.
So, yes you can have fan control and AC control with the SSR ECM Flash.
Thanks for the quick reply.
Tipsy
