Fox Swap Engine Choice
Old Dec 30, 2013 | 03:25 PM
dig's Avatar
dig
Default Fox Swap Engine Choice
Picked up a 93 Fox Notch last week, has been a dream of mine to own one and swap an LS into it. I am mechanically inclined but I have never done a swap myself, I have trolled on all the write up threads and I get the idea, but I want to make sure I don't make a bad choice....so as far as LS Choices on a budget.....I would pretty much be deciding between an LS1 Aluminum block or LQ9 Iron Block correct? I'm planning on running a boosted set up, street/track car, 6spd. What is the best route to go block wise?
Old Dec 30, 2013 | 03:26 PM
dig's Avatar
dig
I was trolling in the FS Section and didn't see many long/short blocks for sale, any advice on where to score a good deal?
Old Dec 30, 2013 | 04:35 PM
06Sierra2's Avatar
Local junkyard 5.3 tough as hell and the dished pistons are perfect for a boosted setup. Or call tms for a forged setup depending on budget
Old Dec 31, 2013 | 10:37 AM
dig's Avatar
dig
I think i'm now leaning more towards a EFI 6.0 Set up which will eventually be running a mild blower for street/track fun.
Old Jan 1, 2014 | 08:34 PM
bmeyer40's Avatar
5.3 can be had for $400 and will definitely hold some boost. If you can afford a 6.0 definitely the route I would go.
Old Jan 2, 2014 | 11:32 PM
dig's Avatar
dig
thanks for the info guys, i'm hunting for an 02+ LQ4 short block at the moment, I have a separate build thread I started that will be updated as I make progress.
Old Jan 3, 2014 | 10:54 AM
5.3Notch's Avatar
My brother in law has a boosted 6.0 in his Fox, was making 750+ on the stock short block before a piston gave way, I have a 4.8 in a fox that I plan on boosting. It all comes down to how much $ u want to spend. $1500+ for a 6.0 or 400-500 for a 4.8-5.3. best part is, if you build it with a 4.8-5.3, you can swap long blocks later, thats my plan, all dimensions are the same.
Old Jan 3, 2014 | 12:47 PM
dig's Avatar
dig
Thanks for the info, my plan is to be running around 600whp on a safe tune on the stock bottom end, I have heard stories about the rod bolts so those will be the only upgrade I do.
Old Jan 3, 2014 | 01:22 PM
BigEd_72455's Avatar
and that can be done just as easily and cheaper on a 5.3 than a 6.0. Unless you are wanting to just throw money away and say I HAVE A 6.0!!
Listen to what info is being given. Not to be insulting but get the 6.0 fever out of your head.
they are good engines, but so are the 4.8 and 5.3 engines that will do exactly what you are wanting to for way less money, and for the most part they are just as durable and will hold up just as well, not to mention more readily available.
Old Jan 3, 2014 | 02:10 PM
dig's Avatar
dig
School me on 5.3 blocks, I'm assuming this is an LS Series block? Any one in particular I should be looking for to be cost effective? How much will stock bottom end handle safely?
Old Jan 3, 2014 | 02:12 PM
LM7 5.3
iron block, aluminum heads
they popped 1400+ out of a bone stock 4.8 on a turbo setup a couple years back trying to test for durability.
do a search here for 5.3 builds.
for 600 hp, the stock intakes should handle that much. but for giggles you could put a victor jr efi with intake elbow and 90mm throttle body, 80 pound injectors, good tune and 18 psi max turbo setup should put you above 600 hp all day every day.
Old Jan 3, 2014 | 02:42 PM
Twin turbo c5's Avatar
6.0 is my first choice . but I've made good power with the 5.3's and 4.8's . either one will work fine in stock trim.
Old Jan 3, 2014 | 03:23 PM
dig's Avatar
dig
So now moving on to another question.....
Is this swap not for the faint of heart? I have a basic garage with basic tools nothing fancy, I have never performed a swap or made heavy modifications to a vehicle, but i'm mechanically inclined and patient. Am I just getting myself into trouble trying to do this in my garage?
Old Jan 3, 2014 | 03:44 PM
geoff17's Avatar
No there are plenty of us that have done this same swap in our garages
Old Jan 3, 2014 | 03:46 PM
dig's Avatar
dig
Thanks for all the input everyone, i'm now looking around at 5.3's and locally they are all over the place, once I purchase I will update my build thread and start asking about head/cam choices. Feel free to look up the build thread
Old Jan 3, 2014 | 04:50 PM
**** man, you are lucky with a garage!!
I did it in my back yard literally with a come-along and a flatbedders strap from a big rig flat bed!! I had a 15 gallon air compressor and a 3 drawer craftsman hand tool set, with minor stuff like sawzall and cutoff wheel.. And I got mine done..
Old Jan 3, 2014 | 04:57 PM
I will tell you this much, until you are COMPLETELY done with the swap, DO NOT CUT a single wire from the original harness. Unhook, disconnect, and unbolt everything and save the harness until you know for certain you wont need any of it.
OK??
Old Jan 3, 2014 | 05:28 PM
FrossB's Avatar
Sounds like that is from experience lol care to elaborate on which wires will be needed??
Old Jan 3, 2014 | 06:41 PM
On my S-10, yes its from experience. I cut the main harness when I could have used some of the original engine's connections to make dash gauges work properly.
Old Jan 3, 2014 | 07:21 PM
OK??
Oh yeah, I forgot to tell you, label the connections as you disconnect them.
