anyone cut down a vortec tensioner to fit ls1 water pump?
anyone ever shorten the legs on a 5.3 belt tensioner to match the length of a LS1 style tensioner?
water pump spacers + ls1 water pump + 5.3 tensioner = too long
I'm cheap. if this can be done i will remove the tensioner from my ls1 camaro and hack saw the 5.3 unit to match.
you guys are right. i can get a gates tensioner from ebay for $33.
Im running an ls1 intake manifold, truck cable throttle body, 3/4" dirty dingo spacers, ls1 car water pump, and a 5.3 balancer. Accessory drive is a billet setup from LS Brackets that mimics the Ls1 F body but does away with the power steering pump by using an ribbed idler. set up for the 5.3 belt line.
my 5.3 tensioner has two small legs. looks a lot different than the ls1 unit. installing it looks like it will stick out a lot further than the crank pulley. i don't have a belt to verify this tho.
I cut mine to fit a car water pump. Wasn't hard. I used a grinder to cut mine down and a sand paper grinder to feather it out and a little at a time to get the alignment right.
