My 90 LX LS/Tremec3550 combo
Old 05-29-2014, 10:28 AM
  #41
onequiklx's Avatar
few more pics
1st is 3 in flowmaster 44's with flow master 3 in ss tip tail pipes, have 3 in universal x pipe also.
2nd is setting ride height
3rd is back wheel on. susp is fully extended
4th front end is back on
5th another angle of back wheel/tire
Attached Thumbnails My 90 LX LS/Tremec3550 combo-exhaust.jpg   My 90 LX LS/Tremec3550 combo-10385027_10201873239857377_1128132145_n.jpg   My 90 LX LS/Tremec3550 combo-10416705_10201894488948591_540975487_n.jpg   My 90 LX LS/Tremec3550 combo-10364274_10201873241457417_2090822296_n.jpg   My 90 LX LS/Tremec3550 combo-10423550_10201891362310427_1469375754_n.jpg
Old 05-31-2014, 10:39 PM
  #42
onequiklx's Avatar
Was able to get my car out of the garage today and cleaned up. still awaiting exhaust then its off to paint
Attached Thumbnails My 90 LX LS/Tremec3550 combo-first-day.jpg   My 90 LX LS/Tremec3550 combo-first-day-2.jpg   My 90 LX LS/Tremec3550 combo-first-day-3.jpg   My 90 LX LS/Tremec3550 combo-first-day-4.jpg   My 90 LX LS/Tremec3550 combo-first-day-1.jpg
Old 06-09-2014, 12:12 PM
  #43
onequiklx's Avatar
I got a 4 in cowl on it and i also took the 275/60/15 pro radials off and put 255/60/15 street radials.
Attached Thumbnails My 90 LX LS/Tremec3550 combo-20140608_122545.jpg   My 90 LX LS/Tremec3550 combo-20140608_122505.jpg   My 90 LX LS/Tremec3550 combo-20140608_122437.jpg
Old 06-09-2014, 01:20 PM
  #44
1slo5ohh's Avatar
Cars looking good man
Old 06-09-2014, 03:32 PM
  #45
onequiklx's Avatar
Thanks. Its fixing to go to the body shop for new paint. Quarter widows and new body molding
Old 06-09-2014, 05:19 PM
  #46
LLave's Avatar
Isn't the 3550 a ford tranny? What did you use to adapt it?
Old 06-09-2014, 07:08 PM
  #47
onequiklx's Avatar
Yes its a ford trans. Quicktime Rm-6037 bell housing is for ls motor and ford t5, tremec 3550 or jericho. Im still using factory style clutch cable also.
Old 06-09-2014, 09:18 PM
  #48
N20neenee's Avatar
Im guessing you used a mustang clutch disc to mate up with the Tremec input shaft, is the mustang pressure plate able to handle the LS1? What pilot bearing did you use?
Old 06-10-2014, 04:31 AM
  #49
1slo5ohh's Avatar
Did you need to modify the clutch fork to work with the factory cable set up? I'm just starting my swap into a 95 and I'd like to go with the T56 but stay cable. I haven't done a whole lot a searching on the subject because I'm a ways away from gettin to that point but what little I have looked up it looks like it may be a pain.
Old 06-10-2014, 06:55 AM
  #50
onequiklx's Avatar
i used a custom spec stage 3+ they made for me. its an 11 in ls pressure plate and disc for my input. I used a pilot bearing from modern driveline. its just a brass bushing style. id prefer a roller bearing but couldnt find one.
Old 06-10-2014, 06:57 AM
  #51
onequiklx's Avatar
I used a 96-88 clutch fork being its 1 inch longer. I did have to massage the floor board to clear the fork but nothing too bad. I just got it driveable and the clutch/trans works great. Gotta say it feels stronger on motor than last "ford" combo on spray lol.
Old 06-10-2014, 08:03 AM
  #52
SSSTANG#1's Avatar
I still haven't started figuring out my combination, Ford T56 Magnum to LS block and using cable clutch but your deal sounds very promising. I'd be happy if QuickTime had a BH for my setup so I don't have to change adapter and input shaft.
Old 06-10-2014, 10:41 AM
  #53
onequiklx's Avatar
thats a nice piece u got there. Only thing about the 6 speed is its easier to make it work with a hyd setup. they make an entire kit to convert it to hyd.
Quick Reply: My 90 LX LS/Tremec3550 combo
