Newb needs some help with parts selection
So far I'm thinking of a LY6 block with stock bore and a 4" stroke, L92 heads,5.3 oil pan, and then from there I have no clue. So suggestion would be helpful.
Next question is how hard would it be to keep the VVT and install a newer gen motor and trans into my truck. Can a keep my existing ecu or do I need the one out of the donor truck?
Lastly please be gentle I'm new to this stuff.
Price wise you might be better off just getting a 6.0L motor out of something else that is compatable with what you have. That would be pretty much plug and play.
The conversion is doable but it might nickle and dime you to death in comparison.
Think about how you want the engine to behave then call someone to offer you a cam for it or build you a custom one. I seen a thread on here awhile back from Martin @ Tick performance (I think) that announced a new set of truck cams and how they would behave.
Good luck.
its according to what year engine you get, if it has DoD, VVT, or any of that stuff.
Other guys on here know a hell of a lot more on that subject than me.
I stuck with the 5.3LS in a 93 S-10, now I am going carb'd..
If you do a gen IV swap then swap everything from the same model year as the engine and get all the computers and harness stuff and get info from alldata or by searching for your pinouts and have at it.
The new 6spds are no screamin hell of a trans anyways. 4L80e is a way better choice in terms of power capability, cost, and parts availability etc. Not to mention 10 times easier to install and tune than the 6spd.
If mileage is what your after stick with the 4L60 and drop the rear gear to a 2.73 and leave the stock cam alone in a 4.8L and enjoy 30mpg if you drive at or near speed limits on the hwy.
