Desperate - '06 Vortec Cruise Control
Diagram below
If you can post up the schematic (take a picture of it if you have to) I can tell you where to hook the 3rd brake light.. The LEDs won't adversely affect the cruise at all, the reason I asked if you had LED taillights is because they don't have enough resistance for the PCM to see its ground through them. But just tapping off the side of the brake light switch that is hot with the brakes applied will work.
And thanks BigEd for the relay info.
Steve
having cruise control is a must for me so #1 "tag" this thread. i am a bit confused (happens all the time) about the relation to LED tail/brake lights and cruise control. can someone clarify? i'll reserve more questions for later since my 05 DBW LQ4 engine and accessories are in route to me now so i'm just getting into the game. i have plans to use LED's wherever possible to minimize load, and cuz i like them. i.e. headlights, tail-lights, interior lighting, etc... hence the question.
