Help determine a year of 5.3 motor?
Old Jan 19, 2014 | 01:37 PM
kodyowenby10's Avatar
Default Help determine a year of 5.3 motor?
Im looking at a LM7 guy swares up and down it came out of a 05 truck but it does not have flat top pistons has single feed fuel line 706 heads blue/green ecm connectors and is drive by wire. The only thing it doesent have is ecm. The only number I cant get to cross on it is sticker on back of drivers side head 10WCJK043452079 is there a way to check this number and maybe figure out a year of the motor?
Old Jan 19, 2014 | 03:41 PM
ls1nova71's Avatar
A 4.8 would have flat top pistons, a 5.3 would have dished, so the seller is probably right.
Old Jan 19, 2014 | 04:01 PM
what about putting a year on it to know if its got the better rods?
Old Jan 19, 2014 | 04:04 PM
Jason454's Avatar
It's usually the 10th digit of the vin tells year.
Old Jan 19, 2014 | 04:44 PM
truck it came out of is gone only thing to go by is number on white sticker on the head the number on block only shows it is a 4.8/5.3 block
Old Jan 20, 2014 | 07:23 AM
Old Geezer's Avatar
Default Look..
Around the filter area/rear of dr side of the block. Should be a VIN lasered there.
If it still has the trans on it, that same # should be lasered on the bellhsg on the dr side.
Old Jan 20, 2014 | 08:36 AM
1969x11's Avatar
13mm bolt heads on the valley cover and exhaust manifolds = 05 and later.
Old Jan 20, 2014 | 09:57 AM
cruisin'73's Avatar
Intersting...I did not know that! Bet that helps cut down on broken exhaust bolts.
