MPG Machine
So.....I've decided to drive something that gets good gas mileage.
I can't bring myself to drive a Pirus, Camery or anything else along those lines.
So I figured...LSx conversion geared for fuel economy!
What's y'all's input on a decent looking, fair priced, LSx vehicle/swap say for under 12k?
As an alternative you could pick up a early 2000`s corvette. I have heard the guys with stick trans and longtubes claimed being able to hit 30mpg on the highway.
I built my DD 72 Olds 5.3 under 12k. It's getting combined low/mid 20s with 2.73 rear and manual trans.
Mid 80s G body or f body are cheap, parts readily available, already have hiway gears in the rear end, easy to swap. They're also big enough to be practical for an LSx V8.
Just keep the weight down, gear it appropriately and don't go stupid with a cam. Old Z cars, RX7, 240sx. Unfortunately I can't think of many domestics.
Keep in mind what ever you build, if you go V8 you will not get your money back in gas savings.
I just bought a Mazda 3. I'm getting 34 mpg going to and from work, no highway miles. Very nice car. I think the direct injection is what makes the engine so efficient, the compression ratio is 13:1 and it runs on regular gas.
That's why I said miata. Get an all aluminum 5.3, and it'll be 2500 lbs after the swap, and you won't have to give up any of the things that make it a nice car to try and keep costs down.
Thing a mid size that was available with a small block would be well within his budget, a lot easier, and more practical as a DD.
If you just need a commuter think small as that should net you better mpg but stick with a manual trans. G-bodies are an easy swap and might be a good blend of small (2-door) but large (usable back seat). A 4 door Malibu or wagon might be the perfect car for your needs. If you go auto, get the 60e as it has a taller OD than the 80e.
How come no one has mentioned a DOD engine and keep the feature active? A Miata or S10 with a DOD engine would probably never run in 8cly mode during normal driving but would still have the power when you nail it.
07+ 5.3 with AFM and VVT stock and tuned WELL!!! Tune is everything theres a guy on PT who tuned his stock GMT900 up to 24mpg or something like that. Swap that combo in a lightweight car and maybe 40 is reachable?
I did the swap myself and have about 13k into it. If you get some good deals you could keep it under 12.
Adding an LSx to a Miata is not a technically difficult operation. It's been done hundreds of times, and all the parts are over the counter. Tap a few keys on the internet, and pretty soon all the parts will arrive at your door step.
BUT, it's not a cheap operation, either. The front sub frame alone is nearly $2K. With a used engine and transmission, and doing all the work yourself, it will cost $8-10K.
You really have to sit down with a calculator and see what you might be saving, and how long it take to get even. Lets pick on the Miata again.
Miata: 26mpg, 100,000 miles, $3.20 a gallon = $12,308
Yukon: 15mpg, 100,000 miles, #3.20 a gallon = $21,333
Difference in fuel costs = $9,025.
By the time you buy the used Miata, pay registration, insurance, taxes, and general upkeep over 100,000 miles, you'll have spent more than $9K. Assuming nothing disastrous happens, it will take you over 100,000 miles of driving the Miata to break even in fuel costs.
It's rarely cost effective to buy a second vehicle strictly for fuel mileage.
OTOH, it's hard to put a price on the fun factor.
As for a DD, I've been in a Miata, not the most practical. Might only be slightly more practical than my 68 LS corvette convertible
One other consideration here is emmisions testing. Pre OBDII cars just need a visual inspection. Post OBDII cars would show up on their computer with a lot of emmisions things missing.
I think this is a key point: cost effectiveness. Don't plan on buying a project and swap things around to get better mileage. For example, it would cost you $15K to build a V8 Miata. But you can buy one ready to go for $12K. It's always cheaper to buy some one else's project than it is to do it yourself.
