oil pressure sender
Old Jan 21, 2014 | 06:26 PM
Tennbowtie's Avatar
Default oil pressure sender
whats up guys i need some help, im putting a 05 5.3 in a 87 k5 blazer. Can i use my stock elec sending unit with a adaptor in the LS motor? I was told you could only run mech sender and gauge with the LS is that true?
Old Jan 21, 2014 | 06:43 PM
02_camaroz28's Avatar
Most if not all LS motors have an electric sensor from the factory.
Old Jan 21, 2014 | 06:53 PM
.boB's Avatar
If you use anything but the stock '87 replacement sensor, the stock gauge in the dash will not work.
Old Jan 21, 2014 | 06:55 PM
Tennbowtie's Avatar
thats what i thought, its a two wire elec sensor in there now. Thanks
Old Jan 21, 2014 | 06:58 PM
Tennbowtie's Avatar
Im planning on going back with all new auto meter gauges, most of my stock gauges are crapped out.
Old Jan 22, 2014 | 11:22 PM
.boB's Avatar
The new electric Autometer gauges will come with new single wire sensors. So you can dump all your stock gauge only sensors and just use the Autometer ones.
Old Jan 23, 2014 | 05:42 AM
gagliano7's Avatar
On my 1992 chevy pickup 5.3 swap i bought an adapter from s&p to use the 1992 trucks sender in place of the 5.3 sender. Works just like it did with the old 350.
Old Jan 23, 2014 | 05:57 AM
oldgoat69's Avatar
You will need to use the sender matched to the gauge, an adapter is available from Autometer to mate the new sender(1/8 npt) to the LS metric hole.
Old Jan 23, 2014 | 06:09 AM
jmyers's Avatar
I took the factory sender from the 5.3, broke off the plastic part, cleaned it and then drilled and tapped 1/8 hole in it. Then screwed the s10 sensor into it. No rewire or adapters.
Old Jan 23, 2014 | 09:45 AM
bczee's Avatar
I use the stock sender for the car's gauges. I take the LS oil sender, break off the plastic part, clean out the inners. Then drill and tap the alum peice for the correct thread of the sender. Now you have a no cost adpter.
Thread it all together, connect the wires and your done.
BC
Old Jan 23, 2014 | 10:16 PM
74modified's Avatar
BC
Two ways - left is tapped oil cooler by-pass, Right (with tap) is broken LS sender.
