PCM mounting
Old Jan 22, 2014 | 10:07 PM
31-5window's Avatar
Default PCM mounting
Hey guy's I am wondering where everyone is mounting PCM's what kinda mounts ur using? If your mounting the PCM inside the car what kind of firewall grommet are you using? Pictures please
Old Jan 23, 2014 | 12:39 AM
Andy4639's Avatar
Talking ECU in the glove box
I have mine inside the glove box. I cut a big rubber hose off to make the grommet. Cheap redneck engineering at it's best! I didn't want it on the fenders are even in the engine bay.
Old Jan 23, 2014 | 07:43 PM
i r teh noobz's Avatar
Mine is bolted to the inner fender. I used the tried-and-true 01 S10 PCM bracket.
Old Jan 23, 2014 | 09:31 PM
74modified's Avatar
+1
Old Jan 24, 2014 | 09:09 AM
MX6.0's Avatar
I have mine mounted high up in the passenger foot well. I made a mounting plate with studs/standoffs.
For the grommet I used the stock rubber piece and cut a slit in the bottom of it for the wires. Might be worth your time to get a nice OEM looking grommet from the local junkyard if you don't already have one.
Old Jan 24, 2014 | 09:15 AM
Harris1's Avatar
The passengers side fender is a very popular spot with the S10 bracket.
Old Jan 24, 2014 | 05:29 PM
ls1nova71's Avatar
I just bent up some little tabs and bolted them to the torx screws that hold the cover on the PCM, then bolted the other side of the little brackets under the dash. Simple and effective.
Old Jan 26, 2014 | 06:06 PM
31-5window's Avatar
Thanks for the info I like the S10 mount.
Old Jan 26, 2014 | 08:08 PM
spacemanspif's Avatar
I have an s-10 tray in my stash of extra parts. $25 and I'll ship it to you. PM for more details.
Old Jan 28, 2014 | 01:27 AM
bdr66's Avatar
s-10 mount hidden up under the driver's fender. The wires that do go through the firewall use a bulkhead connector.
Old Jan 28, 2014 | 01:35 AM
BigEd_72455's Avatar
I mounted mine on the mount for the ABS computer right beside the brake master cylinder. I used a part of the housing for my cold air kit and 2 small screws and a couple washers and it was good to go. Ugly as hell without new wire loom, but it worked until I removed it all to swap over to carb'd.
Old Jan 28, 2014 | 05:08 PM
Bilster's Avatar
Lots of great suggestions. Thanks.
