Front accessories
Old Jan 29, 2014 | 08:24 PM
sbf's Avatar
sbf
Default Front accessories
Hi guys I brought a 98 vette Motor with no accessories.i want to run the f body stuff.i will only be using alt,water pump.my foxbody has manual rack so no need for ps.all the water pumps I seem doesn't come with the thermostat.which water pump I need and where to get a 160 thermostat I also want to run a underdrive pulley,what alternator bracket and pulleys I need
Old Jan 29, 2014 | 08:58 PM
M6 Swap's Avatar
You need gto or f body pump crank and alternator. They will line up with each other
Old Feb 1, 2014 | 02:34 AM
1981TA's Avatar
I got my 160 degree thermostat at Rock Auto. I have a Corvette crank pulley FS if you end up going that route.
Old Feb 1, 2014 | 04:12 AM
sbf's Avatar
sbf
Do you have part number for thermostat and which water pump you running
Old Feb 1, 2014 | 08:42 AM
1981TA's Avatar
Nope, rockauto.com makes it easy to find. Look up a make/model/year of a car which came with the style of thermostat you want (a 2000 camaro z28 will have a different style of t-stat housing than a 2007 Escalade) and look at the descriptions in the resulting list of available items. I got mine by looking up a 2001 Corvette base model.
