Fuel pump Question.
A carb low pressure system requires high volume low pressure
a late model efi requires 40-80psi depending on what set up you are running high pressure lower volume
you did not mention what you were doing for pickup rails regulator excreta
If you want it to be reliable you need to plumb the system with the proper size lines fittings and return line set-up. This will keep the pump cool, all the injectors will see full pressure before you return and the voltage will be more consistent.
one of the troubles with inline pumps is the inability for the pump to cool.(depending on the rest of the system of course) You will also see the current demand for the pump to fluctuate quite a bit depending on heat and demand.
