5.3 swap backfires thru exhaust when trying to start
Old 02-02-2014, 02:24 PM
fire67bird's Avatar
Default 5.3 swap backfires thru exhaust when trying to start
I've got a junk yard 5.3 from a wrecked 2002 Suburban that is backfiring thru the exhaust when I try to start it. It will turn over and run for a second but then dies. I used HP tuners to turn off the VATS and have a stand alone program running it. Does anyone know what could be causing the backfire? The engine is on a homemade run stand with the O2 sensors connected with open pipes and the MAF sensor was plugged in but laying on the ground.
Old 02-02-2014, 02:51 PM
94LTZ's Avatar
Are you using the harness and ecu from the same vehicle? If so are any of the wires going to the crank sensor damaged?
Old 02-02-2014, 03:53 PM
wayfastwhitey08's Avatar
over fueling?
too much pre-load on the valvetrain?
stretched timing chain?
bad coil causing unburnt fuel to be pushed into the exhaust and ignited?
Old 02-02-2014, 04:45 PM
fire67bird's Avatar
94LTZ - yes I'm using the harness/ECU that came with the engine. The crank position sensor was what I originally suspected when it had a no start condition. Found less than 1 volt there but no obvious issue. Then I noticed that the CAM position sensor wires were bare going into the sensor. Fixed that and the voltage at the crank position sensor went up to 12.
wayfast - I think you are correct. I had poured some gas into the intake to see if it would fire off because many have reported stuck injectors on these junkyard engines. I got it started and let it run for a min. to get the extra gas burned off. Hopefully that was all that it was.
Thanks for the help.
Old 02-02-2014, 06:50 PM
good deal.
Quick Reply: 5.3 swap backfires thru exhaust when trying to start
