Rear End Ratio Blues
Also, it's a torque converter, not a stall converter; the stall rpm range is just the point at which you're spinning as fast as you can before you start moving (assuming it's in D). Not trying to be a dick here, just clarifying since people often toss these terms around without considering what they mean.
But changing the gears will be just as easy (or easier, since the car will move under its own power) once the engine is in, so there isn't much harm in trying it like it is. Might as well give it a shot, at worst you get an idea of where you are starting from and how much (if anything) you need to change. There isn't any real reason why what you have shouldn't work fine, but good gas mileage and good 1/4 times are sort of opposite ends of the gearing spectrum.
It may be a bit less than ideal for the track, but just look at the 1/4 mile times of the LS1 f body cars. They ran low, mid 13 stock. You'll have more torque, less weight, a little better gear, so high 12s is possible as is. Good milage, drivability too
Try it with your existing rear. Then swap out if needed.
Btw, I love my 68 corvette convertible, LQ9, Richmond 6 speed, 3.08 rear combo.
The LQ9 is somewhat under rated, it's about 400 hp with headers and simple tune. 500 with L92 heads, cam, intake is doable, but most will be above 5000rpm. so I just stuck with the stock LQ9.
http://www.hotrod.com/techarticles/e...#ixzz21ehbAsre
LS motors don't follow all the rules of a 60s SBC, ie, no need for big cams, lots of overlap. Try the 3.08. Vette rears are expensive to swap/rebuild. If you need a better 1/4 mile time, swap it out. But for the street, fun driving, the 3.08s will be fine.
Oh yeah, the C3 IRS is not ideal for 1/4 mile times, so adding hp or better gears might not gain you as much on a stock suspension as it would on other cars.
