welded Truck tb to carb 1" spacer , pics
got it running ,, fire it up real quick with no exhaust ,, i know bad for the valves ..
runs and ideals fine, still need to hook up rest of turbo stuff back up, but im in middle of disc brake swap and all new bussings etc steering .. .. why i didnt put exhaust on ..
One word. Freakinawesome. First time I ever seen a motor start with no manifolds and ive been hot rodding for almost 20 years. Im pumped. This thread has changed my ideas for my whole setup. Now I need to see if I can rig something up for a cable driven TB. Im using the FAST LS EZ EFI 2.0 and it wont work with the DBW.
My first thoughts were "This is stupid, welding a throttle body is going to warp the body and cook the electronics and shaft seals!"
But then you brought up a good point, if it fails, you are out $16!!
IF the welding does cause problems, but the concept of a truck throttle body as a whole works; I bet you could have a local shop machine an adaptor plate. It would fit the intake bolt pattern and opening, and fit up to the throttle body on the top. It would be a simple "2.5 axis" machining operation. Best of luck, hope this all works out and keep us up to date on the performance!
yeah i was worried the heat would destroy the electronics ,, but it didnt ,, it got real hott too .. ive thought about the getting machined peaice ,, but its so much less hassle just to weld it ..
#36
