CTS Oil Pan
Old Feb 8, 2014 | 12:54 PM
Modchevelle's Avatar
Default CTS Oil Pan
Where can I find a cts oil pan and pickup cheap for my chevelle? Is the cts dipstick and tube different from a truck? Thanks
Old Feb 8, 2014 | 01:08 PM
garys 68's Avatar
ebay, looks like 5 left.
http://www.ebay.com/itm/LSA-oil-pan-kit-LS1-LS2-LS3-LS6-LQ4-LY6-LSA-6-0L-5-7L-6-2L-Automotive-Rear-sump-/221303115725?pt=Motors_Car_Truck_Parts_Accessories&hash=item3386b18fcd&vxp=mtr
Old Feb 8, 2014 | 01:13 PM
bczee's Avatar
Warning.. the CTS-V pan will hang below the Cross member around 1". If you have a lowered Chevelle.. you are going to be bottoming out on it.. You will be scraping on speed bumps, pot holes and anything that sticks up.
I when back to a Notch F-Body pan and not switching to a Holley 302-2 pan. That is my recommendation..
BC
Old Feb 8, 2014 | 01:20 PM
garys 68's Avatar
bczee has a point. I'm running standard ride height, so no worries (pic below). But if you're lowering, you might reconsider.
Old Feb 8, 2014 | 05:08 PM
The F pan looks good but you have to notch the frame and move the brake line right? How much work is that?
Old Feb 8, 2014 | 07:21 PM
chuckd71's Avatar
Mine doesn't hang an inch, but it does hang. Where are you located? I have one without those four screw holes on the side.
Old Feb 8, 2014 | 07:27 PM
bczee's Avatar
Yeah.. Since I was putting a new line in and using a Adjustable P-Valve.. I was able to move and bend the lines enough to removing the OEM Valve away from the Headers.
I Just notched my F-Body pan some.. but not as much as a normal S&P notch.. Here is a picture of it as compared to a CTS-V Pan
I only notch enough to clear, I didn't have to mod the pick up, but the baffle around it only.
The ones without the four bosses on the side are the earlier CTS-V, without the oil cooler. I had two that I brought back then that were pull off from Roy Brizio (he replaced them with F-Body for some rosders he was building) and I sold one to Phil at BRP Hot Rods. He used it to build the install kits he markets
BC
Old Feb 8, 2014 | 07:40 PM
Meangreen1's Avatar
I went the CTS pan way and its about 3/4" on my setup. I am hoping with good suspension it will improve my chances of not hitting it. Time will tell and I will cross that bridge when that happens.
Has anyone tried to shorten up a CTS-V pan?
Old Feb 8, 2014 | 09:51 PM
bczee I really dont want to chop the frame and my car is not lowered yet.I also I have the LS book which there are pics you produced. Great job.What about the pan with the bosses..can they be milled off?
Old Feb 9, 2014 | 03:22 AM
garys 68's Avatar
Why do you want do mill the LSA oil cooler bosses off?
Old Feb 9, 2014 | 09:00 AM
Why do you need the cooler bosses?
Old Feb 9, 2014 | 10:33 AM
garys 68's Avatar
You don't, it's just extra work to remove them.
Old Feb 9, 2014 | 12:08 PM
Ebay has used pans for almost the price of a new pan,Il probably get a new pan. As far as cutting the frame to install a F pan that is out of the question on my car. The frame and body is mint and if I decide to put a traditional engine back in it I can without hacking the car up.
Old Feb 11, 2014 | 04:57 PM
bczee's Avatar
Yeah, Shawn consulted me on my Chevelle swap and I gave him information and also access to my pictures for his book. In return he helped me with some discounts on parts and one of the new JZ Retro oil pan before Holley got the rights and started marketing it under there name.
I think you should have your answer on the removal of the bosses.. but yes you should be ok...
BC
