Help me finish planning my LS1 swap into 1954 Chevy car
#161
The Painless Performance Chassis harness has two spare fuses that are Keyed On power and two that are Bat power., they are limited to a 10Amps and unfused. There are also a few spare hot wires from the harness, but those are mostly for a 15 Amp fuse.
#162
Yes, you need a wire that is hot in crank and run. This wire gets connected to a bus in the distribution module. This bus powers the #86 terminals of the installed relays. There is also another bus that get hooked directly to the battery. Power from that bus is then fused and fed to the #30 terminal of any installed relays.
Andrew
Andrew
#163
Seems like I'm done wiring everything. I want to get some more of that corrugated plastic tubing to tidy up the electrical wires. Planning to run through the test procedure on Saturday or Sunday when i can dedicate an entire day to the task.
Different category of question: How close should the O2 sensor bung be located tho Exhaust manifold outlet flange? Current i have a J pipe from the manifold then have the bung about 8-12" down the straight length. I did that for fitment purposes but wondering if that is too far from the exhaust manifold itself?
#164
My 4L60E transmission does not have the Neutral Safety Switch/Reverse Light Switch mechanism. I am running an Ididit Column shift Steering Column and the Ididit flexible shift linkage. The PSI Engine Harness has a NSS Switch that is part of the Brake Light Switch so i think many years ago i must have gotten rid of the factory switch.
What have other done for a reverse light switch?
