Transmission cooler
so bypassing the rad cooler to heat it up can possibly cause problems if in colder climates .
and b&m makes a few coolers with 12volt fan built in to work for jobs like this . cant get the air flow you need then mount this style and wire it up . already has temp sender in it just needs 12volts .
