Pilot bearing
Old Feb 26, 2014 | 09:49 PM
hifi875's Avatar
Default Pilot bearing
Im am installing a t56 from a Gto in my 69 camaro that currently has a 2004r. What pilot bearing do I need? I have a 5.3 iron block
Old Feb 26, 2014 | 11:50 PM
gnx7's Avatar
Fbody pilot bearing
Make sure that the input shaft doesn't bottom out in the back of the crankshaft. Some truck cranks aren't drilled as deep. Meaning.... don't force the two together by tightening the bolts. They should go together without a ton of force.
If they don't.... I had to trim about 1/8" off my input shaft (alum 5.3) and put a bevel back on the end. Solved that issue.
Also a GTO bellhousing will need some clearancing to run an Fbody or truck starter where the snout goes in. Just makes a mess.... but needs to be done unless you run the GTO starter ($$$).
Old Feb 27, 2014 | 03:43 PM
hifi875's Avatar
thanks, I have the gto starter plus I have a existing powermaster starter on my car now that may or may not fit, prolly will. If so ill have a extra starter. im ready to get this tranny in, that's for sure.
