Alt to starter Cable recomendations ?
Old Mar 3, 2014 | 04:39 PM
adrynalinjunkie's Avatar
Default Alt to starter Cable recomendations ?
I need to buy a good positive cable to connect the alternator to the starter.
I do have the bigger 145 Amp truck alt. so I need something 4 Awg or better.
Any ideas on were to get a good quality one?
Old Mar 3, 2014 | 05:06 PM
gofastwclass's Avatar
With nearly everything else on my custom vehicles... I make my own to fit the application. That way I can route it as I wish when things aren't in factory locations.
Old Mar 3, 2014 | 05:50 PM
Jimbo1367's Avatar
I bought some battery cables from Detriot Speed Eng. and they are by far the nicest cables I've ever had. I believe they are repackaged "QuickCar" I'd look into the gauge you want from them. FWIW
Old Mar 3, 2014 | 06:29 PM
Gray86hatch's Avatar
http://allstarperformance.com/product.htm?prod=6
http://allstarperformance.com/product.htm?prod=737
Nice stuff
Old Mar 3, 2014 | 06:46 PM
LsoneGT's Avatar
I make my own as well. I use welding cable and Napa has a great selection of copper ring terminals.
Old Mar 4, 2014 | 06:52 AM
Pop N Wood's Avatar
Good cable is expensive. the more strands, the better and the more expensive
http://www.wiringproducts.com/automotive-battery-cable
http://www.hifisoundconnection.com/S...8083/SFV/30046
I've had good luck sourcing cable off Honda's in the pick and pull.
Old Mar 4, 2014 | 10:08 AM
cruisin'73's Avatar
Default Welding Cable FTW!
I used 4Ga and 1Ga high strand count welding cable for my re-wire process. It is worth it to spend the extra $$ to get the nice soft cover stuff for its flexibility. And the best way I found to cut it was a cutoff wheel on a 4.5” grinder. I also used brass ring terminals from my local welding supply store.
Size wise I ran 1Ga from the trunk mounted battery to the starter, and then 4Ga for the alt to “power distribution center” to starter. Using an amperage calculator; the 4Ga is more than sufficient for 150A for the length of run.
I have more info in my build thread if you are interested.
Old Mar 4, 2014 | 06:25 PM
ZQ8LS1's Avatar
West marine sells cable by the foot & cable ends.
Old Mar 4, 2014 | 06:49 PM
Thanks for all the info guys I really like this place also it has the SGX high temp jacketing and it is free shipping plus I always like USA made stuff
http://www.advancemcs.com/sps/connectivity/battery-cable
They have an ad on eBay for alternator to starter cable
Old Mar 4, 2014 | 08:01 PM
Old Geezer's Avatar
" the 4Ga is more than sufficient for 150A for the length of run."
I guess that's why the OEM'S don't use 4 ga.........
Old Mar 4, 2014 | 09:01 PM
S10xGN's Avatar
I used 8ga and a 100A breaker, no problems here. But then, I only have a 120A alternator and few accessories other than A/C and a dual SPAL fan..
