fox body LSx weight reduction
I will be in the process of putting together an LS1/T56 coupe and want it to be in the 2600lb range with no driver.
I have heard removing the sound deadener and then just spraying on the rust protection paint is all that is needed.
Now it's going to get loud though.
I've heard guys freeing up over 100lbs by just doing that.
You can free up a ton of weight without ever having to touch the sound deadening and carpet.
Suspension, wheels, brakes, cutting all unnecessary tabs and extra metal off.
If you don't mind it, remove P/S, A/C, radio and speakers.
Running a dumped exhaust (right before axle) will free up a lot also without the extra piping.
My build will be daily/track car but I have no issue driving a beer can around for a daily.
I had an old civic hatch I gutted completely and got it just under 2000lbs was awesome.
(hypermileage car for ***** and giggles)
i kept the back seats and added head insulation under the carpet. full interior, full tubular suspension, ls1/t56 combo, heater, no a/c, 5 lug... everything else oem in tact, weighed in at 3160 w/o me in it.
Bed liner is a very bad idea as mentioned above.
The mat sound deadener stuck to the bottom of the carpet, and the asphalt sound deadener stuck to the floorpans, will cut anywhere between 20 and 50 lbs depending on how damp the mat is.
The rear seat delete kits are often as heavy as the rear seat which it replaces.
There is a large steel structure behind the dash which you could remove, it is mostly unnecessary.
If your car has air bags, and you don't plan to use them, you can remove the whole system.
Pull as much unnecessary copper wiring as possible.
There are braces in the doors which can be removed if you are not worried about side impacts or if it has a roll cage.
Replace all unnecessary metal brackets with cable ties.
Remove the dog bone vibration damper from the rear axle.
Convert to front coil overs and aftermarket front a-arms.
In the mid 1990's I had a 1990 LX hatchback which I cut down to about 3040 lbs with me in it. It had a stock 5.0 with stock iron heads, stock suspension, full interior with power windows, 10 hole wheels and no front skinnies. It started at about 3300 lbs with me in it.
My 1989 coupe (circa 2001/2002) was built to run NMRA Drag Radial and had a cage certified by NHRA to 7.99 or 7.49, I can't remember which (point: the cage was heavy). That car weighed in at about 2650 lbs with me in it. It was a pure race car though.
You have fox Mustang, it will never really be "quiet", but that is the reason it is light. The car can be made to be very light, hence it's popularity. If you want quiet and refined, the fox chassis isn't a good starting point.
My goal weight for the car is 2650lbs w/o me and run a vintage air system in car w/ a iron 402/th400 and most interior pieces. I'm gunna do glass doors, possibly glass front cap etc. I'm going to the lightest stuff I can. Planning the team z lightweight 9", minitubs, 28x10.5w slicks, w/ holley dominator EFI and a davis traction control box. Eventually I'm gunna go to an aluminum motor w/ a power glide but I already have this engine tranny combo.
