ls1 vs sbc motor position
I will be using my same bellhousing and trans, and I want to know what the driveshaft length will need to be with the LS1 vs the SBC.
thanks
Joe
Just be aware of oil pan clearance with crossmember. you may have to modify it or change to a different pan. If all will clear, then just get stock location conversion mounts and crank spacer for flex plate for auto or conversion pilot bearing and have dowels removed off flywheel for manual. long block should fall into place.
What motor mounts you use will determine the answer to some of your questions...
The driveshaft length will depend on where the engine placement is...
What trans do you have now, there are dimensional differences and things needed to adapt autos/muncies to an LS1
Do I have the ability with motor mounts to adjust the position of the engine forward and backward in the engine bay?
thanks
Joe
thanks
Joe
You will have to use an F-body oil pan to clear the rack.
While the TCI headers are nice, I wish I would have spent the extra money and gone with Church Boys headers. The TCI headers just barely touch the passenger side control arm, tuck up really tight to the body, and sit extremely close to the transmission shift lever.
