Need part# for connectors
Old Mar 27, 2014 | 03:28 PM
02b4ccamaro's Avatar
Default Need part# for connectors
I bought SSP harness from a guy for my 5.3. I guess he was going to run after market gauges because there is no connector for oil pressures or oil level sensors. So does anyone know the part#s for these two connectors and pins? Or has anyone made there own harness and is not using these connector and would like to sell them?
Old Mar 27, 2014 | 05:55 PM
bczee's Avatar
I know I have a set somewhere in that box in the back yard full of connectors and harness wires.. I can check and if I find them. We can work out something for the postage ..
BC
Old Mar 27, 2014 | 06:12 PM
bczee's Avatar
Ok.. found them... Oil Pressure is White with one Tan Wire. Oil Level is Black with Gray seal and wires are Brown, black/white.. both have a short wire still attached.
PM me you can have them for $10 (postage and handling).
BC
Old Mar 27, 2014 | 07:57 PM
BP Automotive's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Unless you are using obd gauges or a factory cluster you will have to use aftermarket senders
__________________
Standalone LS Swap Harnesses IN STOCK!
LSX, LTX Stand alone swap harnesses. S10 LSX conversion PLUG AND PLAY harnesses, 24x conversion PLUG AND PLAY harnesses. LT1 to LSX PLUG AND PLAY Harnesses.
sales@bp-automotive.com
www.bp-automotive.com
1-888-467-4491
