Injector wiring
Old Mar 31, 2014 | 01:58 PM
jgh64pkup's Avatar
Default Injector wiring
Not sure if this is the right place for this but im converting a 05 truck harness to go in my 99 gt. Im trying to clean up as many wires as possible and i had a quaetion about the pink wires. Can i run a single pink wire for all 4 injectors on one side to the fuse box? so i would have 2 wires for the injectors instead of 8? i figured it would clean up the top of the engine a little. I also plan on removing egr, rear o2s, and routing everything to the factory mustang computer location.
Old Mar 31, 2014 | 05:20 PM
LS1MCSS's Avatar
Run one pink wire for coils and injectors on each side, with a 15 amp fuse.
Old Apr 1, 2014 | 10:29 AM
jgh64pkup's Avatar
So just one wire for injectors and coils? is there any other wires i wouldnt need or could thin out?
