Needing a lm7 wiring diagram!
Old 04-06-2014, 08:07 PM
axelfoxx's Avatar
Default Needing a lm7 wiring diagram!
traded the sr20det that was in my newly acquired 90' 240sx for a full lm7 with everything still on it, full harness, pcm and bcm.. it came off of a 2001 silverado 1500 with the drive by cable tb.. i have done some searching but not quite found what i needed (yes i plan on trying to keep the bcm in to keep cost down and keep from having to hunt down someone who will flash for me.. also keeping 4l60e..) but does anyone have a wiring guide similiar to the ones here where it shows the plug then goes down 1 at a time color and what it is? .. 19 and first big project, and major dealing with full wiring.. have had to wire new pigtails before and etc but thats nothing compared to what this will be.. any help would be appreciated, thanks -Blake
Old 04-06-2014, 08:37 PM
axelfoxx's Avatar
like the one shown at https://ls1tech.com/forums/conversio...rams-here.html sorry links are acting weird
Old 04-06-2014, 09:36 PM
N20zuki's Avatar
http://lt1swap.com/wiringharness.htm
This is the site I used for my conversion.
And FYI its PCM or ECM... The BCM is the body control module.
My advice is take your time, and read the site carefully. The info is very accurate.
Old 04-06-2014, 09:40 PM
axelfoxx's Avatar
i know that, i meant keep the truck bcm.. so i dont have to flash the pcm.. sorry if its worded weird.. trying to just keep costs way down
Quick Reply: Needing a lm7 wiring diagram!
