96 s10 l33 swap
Old Apr 12, 2014 | 05:47 AM
250z10's Avatar
Default 96 s10 l33 swap
first off i want to say thanks to all members of ls1 tech and preformance trucks.net bc over the past 2 years i have read hundereds of post that made this all come together.
so to start off its a 96 chevy s10 ext cab that had a 4.3 5speed.
what im putting in it is a 05 l33 5.3 with 799 cast heads and 04 t56 6speed out of a gto.
i got a little parts happy so i have already got a long way into the project but i wanted you all to know more about it.
i rebuilt the motor and installed a tsp 220r cam and hardened push rods and ls2 timing chain. toped off with lunadi duel gold valve springs.
on top i put a 96mm typhoon intake and 30# injectors with a FAST 92mm tb.
for the trans is a stock build with a spec stage 2 clutch and f body pro 5.0 shifter.
for the rear i went with a ford 8.8 with 373 limited slip and disk brakes.
the rest is tipical s10 swap stuff like lsx swap shorty headers, frame mounts and motor mounts. and a readiator that fits inside the core subort with duel elc. fans.
ill try up loading pics as soon as i can
Old Apr 12, 2014 | 07:32 PM
ZQ8LS1's Avatar
Good Luck !!
I love my LS swap. Post some pics.
Old Apr 12, 2014 | 10:52 PM
250z10's Avatar
i will very soon
Old Apr 13, 2014 | 08:27 AM
250z10's Avatar
here is the start
Attached Thumbnails 96 s10 l33 swap-img_20120904_183436.jpg   96 s10 l33 swap-img_20130719_171114.jpg   96 s10 l33 swap-img_20130719_182356.jpg   96 s10 l33 swap-img_20130905_171751.jpg   96 s10 l33 swap-img_20130918_152125.jpg
Old Apr 13, 2014 | 08:35 AM
250z10's Avatar
and more
Attached Thumbnails 96 s10 l33 swap-img_20130918_152134.jpg   96 s10 l33 swap-img_20131025_193512.jpg   96 s10 l33 swap-img_20131028_191753.jpg   96 s10 l33 swap-img_20131029_175109.jpg   96 s10 l33 swap-img_20131112_165816.jpg
Old Apr 13, 2014 | 08:41 AM
250z10's Avatar
and more
Attached Thumbnails 96 s10 l33 swap-img_20131211_135309.jpg   96 s10 l33 swap-img_20140102_130010.jpg   96 s10 l33 swap-img_20140104_191130.jpg   96 s10 l33 swap-img_20140114_173804.jpg   96 s10 l33 swap-img_20140114_175903.jpg
Old Apr 13, 2014 | 08:46 AM
250z10's Avatar
i dont have a pic but there is a tsp 220r cam with 112lsa in there
Attached Thumbnails 96 s10 l33 swap-img_20140116_191319.jpg   96 s10 l33 swap-img_20140118_094825.jpg   96 s10 l33 swap-img_20140322_180819.jpg   96 s10 l33 swap-img_20140322_180853.jpg   96 s10 l33 swap-img_20140404_181931.jpg
Old Apr 13, 2014 | 08:51 AM
250z10's Avatar
im at a stand still for acc brackets
Attached Thumbnails 96 s10 l33 swap-img_20140409_163840.jpg   96 s10 l33 swap-img_20140410_151750.jpg   96 s10 l33 swap-img_20140410_170853.jpg   96 s10 l33 swap-img_20140410_170937.jpg
Old Apr 14, 2014 | 01:14 AM
250z10's Avatar
had to stop and order corvette brackets. i was going to use truck brackes bc i thought my intake would sit high enough to clear the water pump. but its not so i ordered a corvette ls2, crank pully, water pump and power steering bracket. we will see what this will get me.
Old Apr 20, 2014 | 09:16 PM
250z10's Avatar
i got my corvette brackets and water pump in. everything fit good. i started plugin up my psi wiring harness. got the motor plugged up. now i need to work on the dash.
