Mis-Fire...
Old Apr 19, 2014 | 10:11 AM
350SS's Avatar
You could try unplugging each injector one at a time and see if the misfire goes away. I wouldn't run the engine rpm to high doing this but it may help determine if it is a particular cylinder causing an issue though not whether it is fuel or spark related.
Old Apr 30, 2014 | 10:19 PM
bczee's Avatar
Well, update time. Still getting nowhere...
So far I have swapped the following:
Cam Position Sensor
Coil Pack and wires
Spark Plugs
Intake Manifold Seals
Injectors
Checked wires and connectors
Checked for Exhaust leaks
checked for Intake leaks
Cleaned MAF and TB
Swapped O2's
When I switched the Injectors (for a working 2002 LS1 Set).. it seem to be able the same. But I noticed that the Right side bank is now idling at -10.8 and the Left Side is -1.0 LTFT as before the intake seal swap.. it was bank 1 @ 14.8 and Bank 2 at much lower percentage.
Got a Video on my Cell of my table with Torque showing the fuel trim and the pop.. once I get it uploaded, I will post it.
BC
Old Apr 30, 2014 | 10:34 PM
im-not-guilty's Avatar
You need a scan tool with misfire data to see what cylinder or cylinders your missing on ,,,
Your going in blind and just throwing parts at it and wasting time
Why has no one mentioned this yet ??
Get a scan tool look at misfire data ..
Old Apr 30, 2014 | 11:29 PM
bczee's Avatar
There are no DTC Codes, check with my tuner and he said the file has misfire and relearn enabled.
I am ..using Torque and a Wireless ODBII adapter to monitor. Not finding any codes or anything.
BC
Old May 1, 2014 | 12:00 PM
bczee's Avatar
Adding a video of watching the Fuel Trims.. the pop is about 21-23 seconds from the start.
I am beginning to consider I have a Mechanical problem, going to take the valve cover off on the Left side and check for anything
Old May 1, 2014 | 12:23 PM
douglee25's Avatar
Something isn't right for sure.
Doug
Old May 1, 2014 | 12:53 PM
spacemanspif's Avatar
I've been following this thread just to see what happens with it and am sorry to see that you are still chasing your tail trying to find the cause of the problem.
I know you checked for intake/exhaust leaks but did you check the intake for any cracks when you had it off? Considering the problem switched sides when you put the intake back on makes me think that the intake could be warped, which doesn't seem to be too common in these engines, but maybe there is a hairline crack that being re-torqued caused it to open a little on the opposite side? Grasping at straws, I know, but just an idea to try and help...
Old May 1, 2014 | 01:46 PM
bczee's Avatar
Mike, thanks for the input.. I did a quick look and didn't see any cracks..
From what the reading was before.. 14.8 on Bank 1.. it was lean.. now with Bank 2 is -10.8.. rich and pulling fuel.. (if I have that right). so the switching is got me.. .??
Old May 30, 2014 | 07:41 AM
oldgoat69's Avatar
So what was the answer?
Old May 30, 2014 | 12:13 PM
bczee's Avatar
Found the problen..
Last go round, I removed the rocker arms, push rods to check them, then doing a leak down test.. I found nothing wrong again. But while replacing the plugs, I felt something funny on one of the plug, I removed it, wiped off the dielectric grease, I found a hair line crack on the plug.... I can only think I replace one bad plug and might have cracked this one when I was messing with the headers or messing with something else on the driver side. Or cracked it while installing or it was bad in the first place. So after many hours of diag work checking and checking again, which included checking the plugs, which looked like they were burning clean. And taking suggestion from everyone, it was a $5 plug...LOL... thanks everyone...
BC
Old May 30, 2014 | 02:31 PM
cruisin'73's Avatar
Isn't that always the way it works out!? Sorry you sunk so much time into the issue, but really happy to hear it is such a small repair!
Old May 30, 2014 | 03:35 PM
  #32
bczee's Avatar
Yup.. I might have found it sooner.. but since I got the Nova running during the same period. Half the time was spent working on the Nova and taking it out for drives.. LOL..
BC
Old May 30, 2014 | 04:44 PM
  #33
oldgoat69's Avatar
Always the way. At least you found it. I hate the little dumb ones.
Old May 30, 2014 | 09:56 PM
  #34
lizeec's Avatar
So do I win a donut? My post #6 was pretty darn close. Glad you got it figured out.
