Alternator Connections
Old Apr 17, 2014 | 12:54 PM
eric8's Avatar
Default Alternator Connections
I am having a custom underhood OEM wiring harness made in anticipation of my LS3 swap into my 1972 C10 pickup. I am interested in finding out a few details so that all the wiring is correct and clean looking, and that any stock wires going to places they are no longer needed (I.e. The stock voltage regulator) are deleted. I will be using all Chevrolet Performance parts (LS3 crate motor, wiring harness and engine controller, as well as their accessory drive and accessories.)
Here are my questions to those who have these parts:
1. What is the exact model of alternator included with the Chevrolet Performance accessory drive kit? CS130? 130D? CS144? 144D? I have searched and cannot seem to find these specs.
2. What does the connector look like on the alternator? Number of pins?
3. What does the alternator connector look like for the alternator on the chevrolet performance wiring harness? Number of pins? Does it plug right up to their alternator or need to be modified.
It is my understanding that the alternator will plug up to the one wire on the Chevrolet Performance harness that goes to the ECU. Other than this wire, all I should need is a heavy gauge charge wire going back to the battery, correct?
Old Apr 18, 2014 | 05:24 PM
eric8's Avatar
Frustrating that something so simple and so routinely done apparently has no clear cut answer! So far I have found this online, which tells the connections that must be made for a cs130 alternator to work: http://paceperformance.com/p-3980-se...nnections.html
That's all fine and dandy....but I'm also reading that the alternator connector for the GMPP LS 3 harness only has a one pin connector for the alternator. How is it possible for the alternator to operate with the harness in a one pin configuration??
Old Apr 18, 2014 | 07:15 PM
zamora7's Avatar
Mine is a one pin as well, the only way I imagine it works properly is that the signal is sent through the wire(switched) and it starts charging through the cable that goes to starter and obviously from the starter to the battery. Also from the starter to the ignition switch, I had s bunch of trouble trying to figure out how to do it in a carbed set up but Ron Francis wiring has a connector with a small module(idk what it is) and it is what makes the alternator to kick on.
Old Apr 18, 2014 | 10:35 PM
LS1MCSS's Avatar
The alternator will have the large wire that charges the battery and, as you read, only one small wire going to it. That wire will excite the alternator when needed so it will charge as needed.
Old Apr 18, 2014 | 11:10 PM
eric8's Avatar
So I guess it really IS that simple. One wire from the PCM will make the alternator function properly, and then one wire to charge the battery. So I guess I can tell american autowire to just delete the alternator circuit altogether in my factory underhood wiring harness, as everything will be controlled by the LS3 PCM.
Old Apr 18, 2014 | 11:31 PM
eric8's Avatar
Sorry, still confused. Whether the alternator is controlled by the PCM or not, I still am not seeing how it could work based on the following diagram: http://paceperformance.com/p-3980-se...nnections.html. If the Chevrolet Performance PCM only has one wire going to one pin on the alternator, it would be impossible for it to work assuming the link is correct. Two pins on the alternator need voltage no matter how you slice it. What am I missing?
Old Apr 18, 2014 | 11:49 PM
EFIHARNESS's Avatar
Or just put a 50-200 ohm resistor from ign to pin b in the alt connector. This works for all of the ls alts.
Here is how this works. In the factory set up the with the ign on but not spinning, the regulator inside the alt shorts to ground telling the ecu to turn on the alt light.
when the alt spins, it needs a positive signal to excite the alt to start charging.
you don't need the ecu to control the charging. The resistor is use to limit current. if the
resistor is not used you will burn up the regulator inside the alt.
Sorry for the long post, But we have done thousands of these with no problems. Steve
Old Apr 19, 2014 | 01:56 AM
zamora7's Avatar
If you are going fuel injected I don't think you have anything to worry about other than the bigger cable that goes from the alternator to the starter, and from starter to battery. Pcm will take care of getting the alternator to charge. The link you posted is also showing how to wire it to the stock gauges. They mention the "gen" light (generator/alternator) I'm assuming in case the alternator quits the light will come on to let you know.
Old Apr 20, 2014 | 07:09 AM
LS1MCSS's Avatar
Search for an aftermarket alternator plug and see how many wires come out of it. That will answer your question. The alternator WILL WORK with only one wire from the pcm to the small plug. The pcm will control the alternator. Stop over thinking it.
Old Aug 7, 2018 | 02:43 PM
Chris Tash's Avatar
Default Anyway we can talk Steve? I’d like to pick your brain about this alternator issue.
I’d like to pick your brain on this LS swap alternator problem. My number is2072900479 if you can text or call would be great
QUOTE=EFIHARNESS;18158506]Or just put a 50-200 ohm resistor from ign to pin b in the alt connector. This works for all of the ls alts.
Sorry for the long post, But we have done thousands of these with no problems. Steve[/QUOTE]
Old Aug 10, 2018 | 08:06 AM
squarles67's Avatar
https://www.pirate4x4.com/tech/billa.../Part2/#Wiring
I used this Holley part on mine https://www.holley.com/products/acce.../parts/197-400
Old Aug 10, 2018 | 08:51 AM
Michael Yount's Avatar
There's some info in here Eric -- https://ls1tech.com/forums/conversio...tor-bible.html
My crate LS3 is run by an 08 Corvette ECU (E38 I think). I used a PSI Conversions harness and a 145A alternator spec'd for an Escalade. It has a 4-wire plug, 3 of which are used. This allows the alternator via ecu control to alter output voltage to try and control to the voltage "sensed" at the "S" wire location. My understanding is that the one-wire hook ups basically don't have this ability and default to a 13.7V output. Mine routinely outputs in the 14.4-14.8V range.
