5/16 fuel line ok?
this link gives some very conservative fuel system sizing estimates. You can safely undercut the numbers in the link above by a bit.
To a certain extent going to an oversized fuel pump will make up for undersized fuel lines, but you don't really want to go that way. if you plan any future upgrades you will outgrow that 5/16 line real quick.
Using 5/16" line worked fine with a single Walbro 340LPH pump in that car for years. Even when I was watching data logs at WOT everything looked good. There was a slight pressure drop on a long WOT run on a fuel gauge but not enough to increase the duty cycle of the injectors to an unreasonable amount so I wasn't concerned.
Even still, knowing what I know now I wouldn't try it on anything but a completely stock engine under perfect conditions.
