fan 2 code
Old May 3, 2014 | 10:18 AM
wanderlodge's Avatar
Default fan 2 code
I am throwing fan 2 code PO481 what is the best way to get rid of it can I tie it to Fan 1, maybe just install a relay, or reprogram the PCM any info would be appreciated Tom 6163409178
Old May 3, 2014 | 11:09 AM
ls1nova71's Avatar
If you're not using a second fan, then the "best" way would be to have it tuned out, other than that, you could just add a relay so it sees that the relay is there and will operate it and not throw the code, but if this is the only code you have, you have had other things tuned out of the PCM, so I would go back to who ever did it before and have them turn that code off.
