6 speed G body
Old May 14, 2014 | 11:37 AM
StrokerTA's Avatar
Default 6 speed G body
Anyone done this yet? Looking for some info.
Thanks
Old May 14, 2014 | 12:21 PM
1989GTA's Avatar
Are you talking about the 6L80 transmission?
Old May 14, 2014 | 01:48 PM
StrokerTA's Avatar
T56 trans, manual, with 3 pedals!
Old May 14, 2014 | 01:49 PM
speedtigger's Avatar
Old School Heavy
Yes. There is a guy on here with a 408 in a 87 Monte with a 6 speed.
Old May 14, 2014 | 04:02 PM
user 4737373's Avatar
Which LS variant do you plan on running and with what accessory drive set-up? You'll get better advice from guys here if those facts are known.
Old May 14, 2014 | 04:31 PM
StrokerTA's Avatar
I think I am going to build a 370" engine with a 6.0 iron block.
Put some GM LS3 or LSA heads on it.
And an Magnacharger I've had sitting around.
Only accessories would be PS, and ALT.
Old May 14, 2014 | 06:02 PM
jlcustomz's Avatar
Besides the crossmember mods, g or f-body pedals, bracket for master cylinder, etc, you really need to enlarge the transmission tunnel slightly to keep proper geometry & not have driveline vibration problems. I just slit the top of my tunnel & added a strip of metal back to it.
Everyone will have their different clutch experiences & opinions, my Monster stage 3 with lighter billet flywheel steel has been great.
Also I went with all autometer ultralite gauges including electric speedo when I did the ls1/t-56 swap back in 2002. This was a good upgrade to match the setup.
The one thing about any ls swaps is there are several different ways of fitting & going about each swap issue. There are many more choices now than when I did my swap.
I believe sick speed monte is one of the regulars here with a more recently done swap.
Old May 14, 2014 | 10:16 PM
85GPLEf41's Avatar
did my stock ls1 and t56 swap using a John Bzdel manual clutch pedal
.http://www.ls7montess.com/
working great so far! hardest part was cutting out the master cylinder hole! as for the crossmember I reused the stock 2004r with the mount redone and the cutout for the dual exhaust.. best mod so far!!
Old May 15, 2014 | 02:13 PM
StrokerTA's Avatar
Yea we were going to do AutoMeter gauges anyways.
Anyone use the BRP 2" headers with a 6 speed?
Old May 16, 2014 | 07:29 AM
shockerman80's Avatar
ive used the brp 1 7/8 headers with my swap they use adaptor plates with stock mounts. fit with 1" setback but a little close so I made some 3/4 setback plates for more clearance.
Old May 16, 2014 | 06:42 PM
lt4malibu's Avatar
I had a T56 in mine with the LT1 13 years ago, Bzdel pedal worked great.
Old May 17, 2014 | 07:29 AM
A.R. Shale Targa's Avatar
I thought MERV went to a 430 incher and a slushbox ????
Old May 17, 2014 | 09:02 AM
Cuttin up's Avatar
I have a el camino style clutch pedal hanging from the original pedal set in my cutlass, it just has a longer bolt and bushings to connect it and the brake pedal pad is cut down to match the clutch pedal pad. I used the ls1 f-body master and slave cylinder setup and it perfectly comes up through the g-body's factory cruise control hole, you just have to elongate the hole a little at the top. the trans is tight on the floor, you either old school it and beat the hell out of the floor or cut and raise it a little.
Old May 17, 2014 | 11:41 AM
Old School Heavy
He may have. I know that 408 never ran up to its potential.
Old May 17, 2014 | 12:33 PM
StrokerTA's Avatar
Sounds like a cool deal. You have any pictures?
Old May 17, 2014 | 04:09 PM
N20zuki's Avatar
I used 3rd gen Fbody pedals and modified them to fit the Gbody firewall and hydraulics from a 4th gen Fbody as well. Gforce T56 crossmember, stock Fbody hurst shifter, and BFH mod the transmission tunnel along with 1in setback motor mounts. I am not running 2in headers, but 1-3/4 midlengths (wish I had long tubes)4
Hope the Maggie you intend to run is a TVS2300 with those giant headers, on a 370. Might be overkill for the blower if not.
Old Jun 1, 2014 | 09:40 AM
Number1's Avatar
Check out sickspeedmonte. He builds kits. http://www.sickspeedmonte.com/Clutch.html
