'47 Chevy COE, '03 Silverado, LR4/4L60E
#42
So I've made a little progress, I decided to build an electronic shifter for the transmission. I ordered an linear actuator and some other parts, built a resistor board and put it all together. It seems to work good. I will switch the **** and use the "T" (throttle) **** original to the truck. You can click on the picture for a crappy video. The actuator looks a bit small but has 15 lbs. of pull or push force so it should move the shift lever just fine.
![](http://i562.photobucket.com/albums/ss67/fasttoys/Shifter%20stuff/th_DSCI0865.jpg)
#46
#48
I saw this at the Lake Mirror Classic in Lakeland, FL today. It reminded me of this thread. Sorry I couldn't get a better photo. Too many people walking into the shot.
Tipsy
Tipsy
![](https://img661.imageshack.us/img661/6315/l1qFCy.jpg)
#50
I was down at Specialized Coatings in Huntington Beach Calif. and they are working on a similar project only using an early Ford cab. It is going to be there shop truck. They managed to get a 2012 Van for cheap and will be using that for the frame, engine and running gear. It will be a stake bed. I will try and take some pictures and post them up. I thought of this thread when seeing it.
#51
OK, so I have a few updates: I'm back in the states for good. So on the truck: I remade the body mounts, built a trans mount, installed the drive shaft, installed a 60/40 bench seat from a 1990 Silverado, made the seat mount tilt, cut a big hole in the floor (after adding some supports) for front engine access, started work on the gas pedal (DBW+original), also removed the spring set-up tubes to have a look at how low I could go with 245/75/16 tires. Have a look.
Rob
![](http://i562.photobucket.com/albums/ss67/fasttoys/47%20COE/021-1.jpg)
![](http://i562.photobucket.com/albums/ss67/fasttoys/47%20COE/DSCI0983.jpg)
![](http://i562.photobucket.com/albums/ss67/fasttoys/47%20COE/DSCI0987.jpg)
![](http://i562.photobucket.com/albums/ss67/fasttoys/47%20COE/DSCI0996.jpg)
![](http://i562.photobucket.com/albums/ss67/fasttoys/47%20COE/DSCI1003.jpg)
![](http://i562.photobucket.com/albums/ss67/fasttoys/47%20COE/DSCI1005.jpg)
Rob
![](http://i562.photobucket.com/albums/ss67/fasttoys/47%20COE/029.jpg)
#53
Very cool project. Check out this thread on The Hamb for more ideas for your COE if you haven't already.
http://www.jalopyjournal.com/forum/t...thread.219018/
#54
#55
#58
Been making a little more progress on the COE, Brake mount is complete. I rotated the rack and am working on a new mount set up. Test fit the U joints and looks like all will work out there. I also found an original column and wheel to use instead of the Ford stuff. Next is a little more work in the rear of the cab and then the cab will come off for the last time (I hope).
Rob
![](http://i562.photobucket.com/albums/ss67/fasttoys/47%20COE/DSCI1040.jpg)
![](http://i562.photobucket.com/albums/ss67/fasttoys/47%20COE/DSCI1041.jpg)
![](http://i562.photobucket.com/albums/ss67/fasttoys/47%20COE/DSCI1042.jpg)
![](http://i562.photobucket.com/albums/ss67/fasttoys/47%20COE/DSCI1056.jpg)
![](http://i562.photobucket.com/albums/ss67/fasttoys/47%20COE/DSCI1060.jpg)
Rob
![](http://i562.photobucket.com/albums/ss67/fasttoys/47%20COE/DSCI1038.jpg)
#60
Yes, for the MC and booster I only had like 11 inches from fire wall to hood (COE) the unit is 13 inches long. For the bell crank set-up I have 3/8" flat bars welded to 1/4" inch wall tubing which runs on brass bushing and a grade 8 bolt. I also used 7018 welding rod with good penetration. I am more concerned about the fire wall flexing then the bell crank. Remember this is also a power unit so force applied to the bell crank should only be in the 600 to 800 hundred pound range, taking into account the mechanical advantage of the pedal pivot, in a full panic stop.
Rob
Rob
