VSS output signal/PSI harness
I'm trying to hookup my Dakota Digital speedo by using the VSS output pin on my PSI harness but there's a black wire in that location (pin 50) which is telling me that its used for a ground. I have a 2002, 411 PCM and all the wiring diagrams that I've looked at shows that pin 50 is the correct pin. I believe that the 98 PCM uses pin 55 and on this harness its not used. Does anybody out there have info to confirm which pin is correct?
