350z LQ9 Swap
Turbo build is on the backburner. Just moved to FL so that took priority. Been DD'ing it for the past few months, so that's been pretty nice.
Fuel lines are braided from the block to the tank. Stock in tank pump. Need to throw a 225 in tank and some new injectors so I can slap this cam in.
Super slick car, sir.
Quick observation of mine, if you don't object, is if a turbo is in the works, back burner or not, wouldn't it behoove you to get a bigger fuel pump now? A 225 isn't going to be enough when you put on the hairdryer.
No, you're right. I was going for something quick and easy just so I can run the cam. The turbo realistically probably won't go on for another year or so.
Love your build!!! Not to hijack your thread but do you know if the Procharger system from a Silverado will clear the hood and driver side head light?i ask because I have a Procharger system from a Silverado laying around I pulled of my truck and if possible I would like to utilize it.
If you're local to FL, feel free to come by and do some mock up.
