03' standalone wiring conversion
Old Jun 16, 2014 | 09:40 AM
Grayguy's Avatar
Default 03' standalone wiring conversion
I have an 03' suburban wiring harness I will Be using for my build. So far I have used lt1swap.com to figure out most of my plans, but one of the things I'm wondering about is keeping AC. On lt1swap.com he has it very well Laid out on what I can delete from the harness, but I assume if I want to keep AC I just don't delete anything having to do with the AC system?
Old Jun 16, 2014 | 11:38 AM
oldgoat69's Avatar
What is the engine going into? That may have more to do with answering your question. I am using all of the OE vehicle wiring to run the AC in my car. I only used the signal request to step up the idle and switch on the fans. Works like a champ.
Old Jun 16, 2014 | 03:00 PM
Grayguy's Avatar
It's going in a 98' subaru legacy with currently functioning AC. I am hoping to adapt the subaru compressor to the LS accessory drive, but even if thst works I'm Not sure how to go about wiring it.
Old Jun 16, 2014 | 09:06 PM
ls1nova71's Avatar
2003 and up trucks don't have a 12v A/C request wire, its run on a serial data line. There is a way to convert the serial data to the older 12v request though, but I'm not sure what tuning software you need to do it. Theres a sponser on here that can do it though, I think its BP. Other than that, you need to find out if your Subaru controls put out the 12v from the switch, if not then all this is moot.
Old Jun 17, 2014 | 01:13 PM
BP Automotive's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Thanks for the mention! Yes we can convert it to the old style wired A/C request.
Bill
Old Jun 17, 2014 | 08:21 PM
FastKat's Avatar
It's good to know that there's an active sponsor that does this. I struggled with this years ago but I never got around to putting A/C in the car.
Could you use a tune from a 2002 truck instead?
Old Jun 17, 2014 | 09:07 PM
LS1Tech Sponsor
Not for the Blue/Green DBW you cannot.
__________________
Standalone LS Swap Harnesses IN STOCK!
LSX, LTX Stand alone swap harnesses. S10 LSX conversion PLUG AND PLAY harnesses, 24x conversion PLUG AND PLAY harnesses. LT1 to LSX PLUG AND PLAY Harnesses.
sales@bp-automotive.com
www.bp-automotive.com
1-888-467-4491
Old Jun 18, 2014 | 05:38 AM
aknovaman's Avatar
Simplest way is to run a 2003 express van file with manual AC and wire it as such.
Old Jun 18, 2014 | 06:19 PM
Grayguy's Avatar
Bill
Which part of the wiring would I need to keep for this?
Old Jun 22, 2014 | 06:50 AM
aknovaman's Avatar
This should help you for standalone config.
https://spreadsheets.google.com/spre...KSkg2Z3c&hl=en
Old Jun 22, 2014 | 07:47 AM
LS1Tech Sponsor
All of it. Including the ac pressure switch.
Bull
__________________
1-888-467-4491
Old Jun 22, 2014 | 07:51 PM
Grayguy's Avatar
Ok, so I can delete all the normal stuff and leave the AC stuff then have you guys at BP reprogram it to work.
Old Jun 22, 2014 | 08:10 PM
LS1Tech Sponsor
You would have to wire it for the wired ac request. That would be it.
Bill
Old Jun 23, 2014 | 08:35 AM
Grayguy's Avatar
So basically I need to find a van wiring diagram and follow the AC wiring for that?
Old Jun 24, 2014 | 05:22 AM
aknovaman's Avatar
Wink
Yes. Pm me your email and I can send you the info.
Old Jun 24, 2014 | 07:13 AM
Grayguy's Avatar
PM sent, thank you!
Old Jun 27, 2014 | 06:38 PM
aknovaman's Avatar
Here is a link to the manual ac wiring diagram. The PCM file must be set up correctly for this to function correctly (same as express file settings).
https://ls1tech.com/forums/conversio...press-van.html
