'70 Skylark Convertible
Old Jun 16, 2014 | 03:00 PM
kainedogg's Avatar
Smile '70 Skylark Convertible
I just picked up my first convertible this weekend. Well actually my best bud grabbed it for me. I am really torn about doing an ls swap, not because the car is stock (it actually has a '94 sbc) but because the a/c works and in this hot Tampa sun, I don't want to eliminate a key amenity. If I did a swap it would not be performance oriented. Just a 5.3/4l60e with a small cam. How can I keep the a/c without going to vintage air? This is the only thing stopping me from doing the swap.
Attached Thumbnails '70 Skylark Convertible-photo-4.jpg   '70 Skylark Convertible-photo-1.jpg
Old Jun 16, 2014 | 07:04 PM
Chris05's Avatar
Kwik makes brackets for A/C compressors also dirty dingo too.
Old Jun 16, 2014 | 09:00 PM
ls1nova71's Avatar
I'm going to guess that since its got a 94 engine in it that its been converted to 134a? If so, then I would swap it and use the LS compressor with the factory air. You've seen my green truck build, right? Something similar to the way I did it should work fine.
Old Jun 17, 2014 | 08:56 AM
oldgoat69's Avatar
I did the same thing, truck compressor and POA eliminator. Works awesome. Cold Air hoses and parallel flow condensor.
Old Jun 17, 2014 | 09:02 PM
kainedogg's Avatar
Smile
I will review your build again. I do remember getting overwhelmed with the attention to detail your build received.
Forgive my ignorance but what does the reference to cold air hoses and parallel flow condenser mean friend?
Old Jun 18, 2014 | 08:09 AM
oldgoat69's Avatar
That is in reference to a vendor to make up the necessary hoses and an updated condenser with threaded connections vs. pushon. I had a less than positive experience with the pushon from the compressor to the OE condender. All told I spent about $175.00 for a larger more efficient condenser and the correct hoses.
Old Jun 18, 2014 | 09:39 AM
Harris1's Avatar
I'm going through the same thing I want to keep my factory air, and from my research it should work no problem.
Old Jun 18, 2014 | 01:00 PM
kainedogg's Avatar
That is a huge relief. I will get cracking.
