My 69 Camaro LS1 Swap
Here are a few pics of how I connected up my fuel system in the engine bay. For the connection to the fuel rail I used a Swagelok 3/8" 90 degree compression fitting (SS-600-9) which connected to the fuel rail. Then I used a tube insert with a -6AN connection (SS-6-TA-1-6AN) on the end of that. At the frame rail I used a straight tube coupler (SS-600-6) to connect to the 3/8" line and another one of the AN adapters in that. I then coupled it all with a parker stainless braided teflon hose with AN fittings on each end. I think the parker hose is there 919 series.
I'm carbed and used the 1" set-back mounts with the DynaTech 1 7/8" headers...the plug wire hits, so I had to "adjust" it some
I did all of the wiring modifications to the car and engine harness myself and am glad I did. Learned a lot on how this engine is set up. I ended up using a Cooper Bussman fuse block and power relay module that has been posted on this forum a few times. To mount this, I made a new glovebox and mounted it inside. Along with that I made the glovebox shallower and mounted the computer behind it. Using the original computer mount I can now easily remove the computer when needed.
4ga. cable down to the starter from the battery front post. 4ga. cable from the top post to a 200 amp fuse. Ground from the battery to the block and to the frame.
Next from the fuse above the battery I ran 4ga. across the the other side of the radiator support to a battery post. This provides power for the headlights/fans and is where the alternator connects.
From that post I have another 4ga. wire going to another post up by the brake booster. From there power is provided to the wiper motor and all the rest of the car.
