quick dip stick and oil questions
Old Jun 22, 2014 | 05:53 AM
Sloe Truk's Avatar
Default quick dip stick and oil questions
Hi All, I'm putting together my swap engine and have a couple of ?s
1, I'm running a GM crate LS3 and a 2 piece batwing oil pan, if I were to reuse the dip stick tube that came with the motor, which dip stick should I use? or would it be better to get the C5 Z06 dip stick tube as well? I"m having a hard time finding the one listed in the oil pan section.
2, How much oil would this configuration run? This is being built for a road course car.
Thanx!
Old Jun 22, 2014 | 06:25 AM
garys 68's Avatar
I put a 02 vette batwing pan, dipstick and tube on an LQ9. It took over 8 quarts to get near the correct level as indicated on dipstick. My recommendation is look up the oil capacity, 6 1/2 quarts?, for the batwing pan and mark whatever dipstick you use.
Old Jun 22, 2014 | 02:25 PM
DW SD's Avatar
Did you change the oil pump pickup? If not I'd use the level on your stock dipstick with stock dipstick tube.
