Porsche Cayman + LS3
Old Aug 13, 2014 | 12:45 PM
JustinOlson's Avatar
Wound up getting the GM alternator and PS kit. All the parts including brackets and bolts were 1/3 the cost of just the PSM electric pump. I will need to do something with the PS res but otherwise this is plug and play.
Old Aug 13, 2014 | 12:46 PM
Mufflers, flex joints and V-bands showed up this past week. Borla XR1 mufflers. Probably going to add a pair of resonators too.
Old Aug 13, 2014 | 12:53 PM
Outfitting the Cayman with an Arcflash Motorsport Dash. The dash is designed to use AEM sensors as well as many others.
https://www.facebook.com/arflashed
http://www.arcflashed.com/collection...s/digital-dash
This is the same dash being incoroprated in the Palatov D2 as seen here:
http://dpcars.net/dp2/index.htm
Old Aug 13, 2014 | 04:52 PM
Andy1's Avatar
Originally Posted by JustinOlson
Quarter Master 7.25" dual disk clutch with LS3 Button Flywheel. I decided to go this approach so I could reuse the clutch (with $200 worth of new disks spline for GM) when I go with the Quaife Sequential box. The whole package is 1/2 the price of the KEP clutch. Strong and lighter too. ~2" thick spacer to get proper engagement with the factory transmission.
Justin,
Cool build; I'm reading with great interest!
I have a Porsche 914/LS1 with an Audi 01e 6 speed transaxle. I too used a QuarterMaster setup, though mine is the single disc 8 1/2 (rally disc, spring hub). The engagement is pretty ubrupt and mildly annoying for the street. I would speculate yours will be yet more abrupt than mine, but that won't matter if you're tracking the car.
So a couple of questions, if you don't mind:
1.) On mine, I adapted to the Audi TO fork and used the QM radius faced TOB. What kind of TO bearing setup are you planning on?
2.) On your flywheel spacer, did you counterbore for hex head bolts? The crank flange has those funky 11MM threads and AFAIK, only availabe in hex head. After I finished my setup, I got wind that ARP made a special run of long (don't recall how long exactly) 11MM crank flange bolts. You might call them directly and spek to someone in engineering.
Andy1
Old Aug 15, 2014 | 12:02 AM
White Out's Avatar
Love this build.
Old Sep 22, 2014 | 03:35 PM
JohnnyFbomb's Avatar
Love this thread! Any updates?
Old Nov 2, 2014 | 12:06 PM
mapleridge's Avatar
bump. looking for updates too.
Old Nov 2, 2014 | 07:20 PM
kainedogg's Avatar
Subd for the outcome
Old Nov 4, 2014 | 08:18 AM
2muchboostNY's Avatar
Holy sick build and amazing fab skills batman! How did i miss this thread....subed
Old Nov 5, 2014 | 02:16 AM
E36LUVA's Avatar
*subscribed*
Old Nov 11, 2014 | 05:27 PM
rao's Avatar
rao
Great progress, would love to see this in person.
Old Dec 24, 2014 | 11:25 AM
  #32
martsink's Avatar
Hey man, I hope your recovery is going well! Those X ray pics look pretty rough. I have a questions about the throttlebody. I believe that all Porsches 2000+ are drive by wire, so how do you make the Porsche gas pedal work with the LS TB? Are you going to keep it drive by wire, or switch to cable?
Old Jun 13, 2015 | 02:07 PM
  #33
OS inspector's Avatar
subscribed for updates nice build
Old Jul 27, 2015 | 11:31 PM
  #34
rat_rod_russell's Avatar
The project live!!! Just not not here. Lots of updates online at his site.
http://caymanrsr.blogspot.com/
Old Jul 28, 2015 | 10:41 PM
  #35
runsfromdacops's Avatar
wish this guy kept on on his build thread.
Old Jul 30, 2015 | 11:35 AM
  #36
Auto-Mafia's Avatar
bummer I was really looking forward to seeing more here....
Old Aug 3, 2015 | 02:53 AM
  #37
LORDDiESEL's Avatar
I like this thread too. I looked at his site and it looks like he had a gliding accident and broke a bunch of stuff in his lower back.
Old Aug 5, 2015 | 12:46 PM
  #38
You can also follow updates on Josh's digital dash companies website where he post updates.
I will try to post pictures and updates here periodically as well.
Regards,
Justin
Old Aug 6, 2015 | 02:20 PM
  #39
ArcflashLLC's Avatar
I'll try and post updates here guys. But if you need daily info check out my blog or facebook in my signature...
Attached Thumbnails Porsche Cayman + LS3-11802610_457423054437047_7235005472238056363_o.jpg
Old Aug 6, 2015 | 03:53 PM
  #40
Awesome thanks!!!
