lq4/th350
Old Jun 26, 2014 | 09:56 PM
sb50's Avatar
Question lq4/th350
Hey guys I have a 86 monte Carlo I'm doing a swap in. I have the flat 6.0 flexplate with the spacer Sandwiched in between flexplate and crank. I have a Coan converter for gen 1 small block. I know converter is fully seated but when spinning converter it stops on humps on flexplate. So if I bolt it up there the converter won't pull out.So my question is will the trans pump be ok if it doesn't pull out of the transmission a little. Has a anyone had this problem?
Attached Thumbnails lq4/th350-h7grwyzvn1uohxuj2jsuhyczolcvudtpctgqgaezi3c-w185-c-h185-n-o-k.jpeg   lq4/th350-zozhzolwkrcuhz5vkvsjmgyompp6fwwv2w2jigaci_k-w185-c-h185-n-o-k.jpeg   lq4/th350-pobhmiuk_dtptk_8d_0hlahyfsivd1-u5d17hyprbga-w185-c-h185-n-o-k.jpeg   lq4/th350-tcrp6ibjyje9rhrlcwtla00_zqqmnmqsjalfsfgdqla-w185-c-h185-n-o-k.jpeg
Old Jun 27, 2014 | 11:15 AM
sb50's Avatar
So does any know about the trans?
