"A" body trunk floor solutions.
Old Jun 26, 2014 | 10:19 AM
oldgoat69's Avatar
Default "A" body trunk floor solutions.
All right GM "A" body guys, I am finally going to get around to making a trunk floor/fuel pump cover. I am looking for any of your ideas. This is what I have to work with.
Old Jun 26, 2014 | 01:32 PM
1964SS's Avatar
I'm running a fuel cell in the trunk so I didn't deal with this, but what about some type of access panel door welded in for easy access later.
Old Jun 26, 2014 | 03:23 PM
oldgoat69's Avatar
I did consider something like that but the floor is not flat and the pump module sits up too tall. In any event I do plan to hinge the front edge. I am looking for examples of others creativity, before I settle on a plan and see a better option.
Old Jun 26, 2014 | 03:51 PM
jjamm7667's Avatar
Is that a 90's B-body gas tank?
Old Jun 26, 2014 | 06:09 PM
garys 68's Avatar
Metal box integrated into the front lip.
Sorry, only a pic after carpeted.
Old Jun 26, 2014 | 08:30 PM
john 67's Avatar
http://i228.photobucket.com/albums/e...ginebay008.jpg
it angles up so i just tighten all screws a little at a time and I have some weatherstripping sealing it up. JOHN
Old Jun 26, 2014 | 09:17 PM
Project GatTagO's Avatar
Here is mine:
http://www.carcraft.com/featuredvehi.../photo_05.html
Andrew
Old Jun 27, 2014 | 10:10 AM
oldgoat69's Avatar
Yes it is a 96 Impala SS tank with an Aeromotive 340 Stealth pump in a Dorman holder/sender.
I have been toying with the idea of making something in fiberglass that I could easily duplicate and market to others. If I go that direction my plan is to make something more contoured with a piano style hinge at the front. Otherwise it will be more like john67 has created. It just boils down to how creative I am feeling at the time.
Old Jun 27, 2014 | 11:50 AM
bczee's Avatar
I also used a sheet metal cover. I also made a 1"x1/8" steel frame to fit under the floor and above the cover to re-enforce the area around cover where it screws into. I then used some old bicycle inter tube to make a seal which creates a vapor seal and secures the cover very firmly.
BC
