Fuel pressure regulator to plug fuel damper hole
I'm surprised this topic doesn't come up much. This is one of the only other threads I could find on the subject with relation to non-97/98 C5 rails: https://ls1tech.com/forums/fueling-i...regulator.html. I admit, my search wasn't exhaustive.
In another thread, Racetronix spoke of a product they were developing so that F-bodies could mount a regulator in place of the damper. I PMed them a few days ago, but haven't heard back. I'm assuming that project is dead. ![](http://www.racetronix.com/product/RX-C5-LS1-FPR/RX-C5-LS1-FPR.jpg)
After some searching I landed on APS's C5 TT page and was reminded of these Bosch regulators in whatever housing that it comes in. That prompted more searching.
![](http://airpowersystems.com/corvette/c5/apscc5-fss09/reg_ass1.jpg)
A few Google hours later, I found a few sites (Bosch among them) that sell 4-bar, boost referenced, Bosch style fuel pressure regulators. The one I purchased is from Radium Engineering, out near Portland, OR. They seem to cater to Lotus. I bought their universal FPR housing (just in case) which includes -6AN fittings and accepts any Bosch style regulator. The regulator I got from them is 1:1 boost referenced and adjustable.
In the picture below, it's a little difficult to see, but the left and right cross over tubes come into the damper housing, but don't connect into the fuel rail feed tube. To double check, I plugged the center hole in the damper housing (green) while blowing on the feed (cyan), and no air passed through. Then I tried the reverse... I blew through the damper housing while plugging the feed and air exited the injector holes (and the back where I had -6AN fittings welded on). So basically the entire fuel rail works like Radium FPR housing... like I hoped.
![](https://img33.imageshack.us/img33/1950/p1000146e.jpg)
Now what needs to change in my car is, the OEM fuel feed will be converted into a return line, and both rails will be fed from the rear. Good thing I had those AN bungs welded on!
The adjustable, 1:1 boost ref regulator does fit in the OEM fuel rail damper housing. It was a bitch to get that snap-ring in, but it fits.
![](https://img696.imageshack.us/img696/1618/p1000162e.jpg)
With fuel rail covers on. The driver's side cover definitely has to bend out of the way of the regulator. I'll probably leave it like it is, but if I end up with a bunch of problems, I'm going to cut a hole to provide more room like in the Racetronix picture, way above.
![](https://img29.imageshack.us/img29/1715/p1000153e.jpg)
![](https://img267.imageshack.us/img267/8915/p1000158e.jpg)
I haven't installed this yet, and since I'll have to pull (or gut) the regulator from within the fuel bucket, I might as well wait till I can get Lonnie's double pumper. Also, since it was only $10, I'll be using the V6 F-body fuel feed line (goes straight to filter, no T-block fittings required), and probably the return line (goes straight to the nylon line running from the tank). There'll be none of this "I used my evap for a return" for me.
Just in case anyone asks, "why didn't you just spend $150 on new rails and another $150 on a regulator and another $100 in fittings and another $100 in -8 lines?"![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Well, I want to make sure my planned-for wet shot and injectors get the fuel they need when I spray. Also, if I ever go forced induction, I should be good to go. I equally hate the look of stock rails and after market rails, but at least GM made these pretty covers to put on the stockers...
All I need now is a Y-fitting to feed the fuel solenoid. Cake.
Today we started testing our new Racetronix PnP billet adjustable fuel pressure regulator ... [which] will replace the factory rail-mounted pulsator and come with a -6 Teflon line and custom fittings that will plug into the GM push-lock return line at the back of the car ...
![](https://img685.imageshack.us/img685/5148/p1000129ep.jpg)
![](https://img822.imageshack.us/img822/7127/p1000145e.jpg)
![](https://img542.imageshack.us/img542/4156/p1000151e.jpg)
![](https://img585.imageshack.us/img585/3824/p1000156e.jpg)
![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
I bought the spare fuel rail on this site years ago... maybe $40-50? The regulator itself was $49.00. The two -6AN weld-in bungs, -6AN Tee, and 45° fitting were $2.48 (ea.), $11.38 and $12.63, respectively, from Summit (price match policy for the win). The V6 fuel feed, return, and evap lines were $10 for all three from a junk yard. Labor to weld the bungs onto the rail was $60. I'm guessing another $40-50 for -6AN braided teflon feed and cross-over lines that I'll need to buy.
THIS! needs to be a sticky!! i learned so much in very little time, thank you!
it took a google search to come acros this thread but this is great for people that dont want to go to expensive aftermarket fuel rails. this is what i needed
a few more questions on this.
does the stock FPR need to be removed?
i get that that the boot reference is on the fuel rail, but where does the new regulator go exactly? if you had a pic would be nice.
Yes, the stock regulator sitting in your fuel tank needs to be removed. Fuel pressure regulation would become the responsibility of that in/on the fuel rail.
Here you go! Green arrows push on the plunger till your desired pressure is reached then "leak" out as the cyan arrow. I hope to have some free time around the holidays to test the efficiency of this setup before installing it.
![](https://img197.imageshack.us/img197/9885/p1000162e800x500.jpg)
Sorry for bumping a really old topic but I found a regulator that should work ordering it today for $28
Bosch 0280160575 Fuel Pressure Regulator
Should be a 4 bar Hook your vac line up and it should be boost referenced then.
