true gm one wire with holley efi
http://forums.holley.com/showthread.php?14176-Help-with-tune
The biggest most important thing with the holleys is that all your grounds are exactly where they're supposed to be. A dirty ground will give you hell
One wire alternators don't regulate voltage as well as ones with a voltage sensing wire. But the other possibility might be electrical noise. The battery acts as a filter, but if the alternator and box power come right off the same spot it might be seeing power supply noise.
Try charging the battery up also.
I once had an issue with my 84 Camaro running a MSD 6AL box, it would cut out. Fixed it by running the power directly to the battery., and the ground too.. even though I thought I was running it to a good power distribution point... NOT.. !
Without the alternator the system starts at mid 12v and trickles down, with alt its about 14v at idle. I'll post back if these changes fix my issues
From the battery ground, I run 3 wires, frame, block and body. I run more grounds on the block, back of the head to the body (Same lug as the harness/PCM grounds and the from side of block to frame.
Yeah, I know it is a bit must, but bad ground can cause many electrical problem with both the general car and EFI/PCM related issues.
Keep us posted on the results of the rewiring.
BC
Earlier I was saying to NOT hook the box power and charge wire to the same point. Alternators can have some AC ripple, you want that filtered by the battery. The resistance in a length of wire can further help smooth this ripple.
The box power should ideally be off the fuse box. But the way you have it now should tell if the running issues were ground related.
I'm not a big fan of running alternator charge wires straight to the battery either, especially with a one wire alternator, cause it can lead to overcharging the battery. But to get around your current problem it is probably the way to go.
are you sure the alt is a true one wire-I ran 3 wires on mine, I think it was a CS130 or whatever, vette or Camaro one
as said, ck all grounds-if you bat is in the trunk, the alt needs to go off there if you have a kill switch
there could be some kind of interference, esp if the alt is looking for some kind of signal wiring-it needs some sort of sensing to tell it to stop charging
What is your engine combo?
Tim
How would a person run the Holley main power/ground to a battery lug by themselves? I have a normal 2 post battery, Only place I have to hook 12v sources is there or the starter, and I have to run my charge wire to one of those locals. The current setup was just the main Holley power and ground to the battery, charge wire and all other 12v to starter. Going to try it in a bit with charge wire to the battery. I'll start rearranging grounds or adding them from there. I hate electronics, just can't wrap my head around it lol.
2002 5.3L
230/236 114+4 .6xx/.6xx (installed dot to dot)
Holley Hi-Ram
Holley 120 injectors (low imp)
WBO2 is about 1' from manifold exit, with 1.5' of pipe following WBO2
Getting it running for now, twins over the winter and rod/piston motor next summer with parts transferred over, hence the overkill as I don't want to buy twice.
