"cheap" headers for LS/Nova
Old Jul 3, 2014 | 06:27 AM
forcd ind's Avatar
Default "cheap" headers for LS/Nova
curious if anyone has found cheaper headers that fit a 68-72 Nova/LS
the conv. ones are def pricy
Old Jul 3, 2014 | 07:43 AM
Sebtarta's Avatar
What is cheap? Because you can buy the ebay headers as 67Rally did and later on spent more on new headers because of quality and fitment. Or just save the $$$ and when ready buy the headers that are made to specs and fit with no issues and their quality is superior.
Old Jul 3, 2014 | 10:34 AM
88Fbody6L's Avatar
Best cheap option are the Dougs uncoated version. I got mine for under $400 and painted them with VHT ceramic coat.
Old Jul 3, 2014 | 10:45 AM
cruisin'73's Avatar
Default Ebay to the rescue!
If you’re willing to put in some elbow grease, there is a very cost effective option. For my ’73 Nova 5.3 swap I used the infamous Ebay 4th-gen SS headers with great success. The build quality and materials were both good and the price was great at $180. I had a buddy bring over his oxy torch and with some heat and long lever arms we were able to re-align the collectors into position. We also removed the AIR and EGR ports and TIG welded them closed. To finish off I used a scotch brite wheel (several actually) to remove the heat discoloring and give the headers a brushed look. 5000 miles later and I am still very happy with them.
Oh, I did have to indent #3 and #5 primaries to make clearance for the steering gear. Unfortunate but neccesary and IMO acceptable at I could not shell out $800 for proper conversion headers.
Check out my build thread for more details and pics.
Old Jul 3, 2014 | 11:22 AM
forcd ind's Avatar
good info, thanks
Old Jul 3, 2014 | 01:12 PM
LS1 pwrd NOVA's Avatar
Raw steel mid lengths are $350 from hooker.
Or Fbody manis fit driver side is tight.
Old Jul 3, 2014 | 03:11 PM
Doug G's Avatar
I think my DynaTechs were only around $400, and fit good. #7 plug wire is a bitch though
As you can see in the last pic the way the #3 tube is....
Old Jul 3, 2014 | 09:37 PM
bdoobie69's Avatar
Texas speed stainless long tubes here. $500.
Old Jul 3, 2014 | 10:20 PM
What they for or fit exactly
Old Jul 4, 2014 | 08:48 AM
bdoobie69's Avatar
They are made for the first gen camaro
Old Jul 4, 2014 | 06:16 PM
33willys's Avatar
Default Headers
I put raw steel headers on my ******. Got some Eastwood stainless header paint, cut it with Xylene and sprayed on one THIN coat. They looked good for over 6 years, didn't have brush marks and didn't peel. Trick was to stop with one thin coat.
Old Jul 5, 2014 | 09:49 AM
Pocket's Avatar
http://www.racinginnovationandsupply...der_p_189.html
Try these
Designed for a LSx 82-92 Camaro, super tight to the engine/trans collectors angled slightly inwards to the trans
Old Jul 7, 2014 | 10:54 AM
cruisin'73's Avatar
Try these
damn, those look pretty slick! I bet they would give much better clearance around the steering gear in a 4rd gen nova. Nice price too, AND SS!
