Lean at WOT and won't idle.
Old Jul 17, 2014 | 12:15 PM
curbcheck's Avatar
Default Lean at WOT and won't idle.
1995 240sx with an lsx swap and a 228/228 cam, car ran good for a few months, then I developed rod knock. Pulled the motor and rebuilt it with stock in internals. Now sometimes I can get it to idle and sometimes it wont. When I can get it to idle, my wide band reads 14.8 to 15.4. When I Rev it the idle will start surging and it will stall. Finally decided to take it for a spin and it is lacking power at mid throttle, wide band reads about 15.7. When I go WOT wide band doesn't even register. Fuel pump and filter is new. Fuel pressure is good. Vacuum gauge reads about 16 to 18 inches at Idle. I'm about to go do a compression test as soon as I finish typing this. Could my cam be off 1 tooth and still run somewhat? Anybody have any other ideas?
Old Jul 17, 2014 | 12:30 PM
curbcheck's Avatar
Ok just did a compression test on 1, 3, 5, and 7. I'm getting 160 across the board. Seems a little low but it's consistent.
Old Jul 17, 2014 | 01:22 PM
curbcheck's Avatar
Just finished up the passenger side, all 8 pistons I'm getting 155 to 160 on a warm motor. Oh and by the way it is tuned for the cam.
Old Jul 17, 2014 | 08:51 PM
curbcheck's Avatar
Just finished putting the motor back together. Timing chain was installed correctly. I'm going to clean the maf ckeck again for vac leaks and recheck fuel pressure tomorrow. I don't know what else to look for.
